Please explain syntax - [](AsyncWebServerRequest *request){
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
        request->send(200, "text/plain", "Hello, world");
looks like the 3rd argument may be a ptr to AsyncWebServerRequest.
i don't understand the "[]" preceding it?
i don't understand what looks like function body following it?
It is a lambda expression, sort of an unnamed function.
can it be replaced with a more conventional function ptr?
Yes, I think so, let me check.
It seems to consume a parameter of type ArRequestHandlerFunction, which is defined as follows.
typedef std::function<void(AsyncWebServerRequest *request)> ArRequestHandlerFunction;
So perhaps you can try to use a callback function like this:
void callback(AsyncWebServerRequest *request) {
Acts like:
void RootFolderHandler(AsyncWebServerRequest *request)
    server.on("/", HTTP_GET, RootFolderHandler);
The lambda expression is handy when you need the address of very short function just to pass it to another function.
thanks
so the "[] " is identifying it as a lambda expression?
That is how I recognise it, but there can be something in between the brackets. This is explained in the "Lambda capture" section of the link I posted. The full syntax is also explained there (at the top of the page).
i saw that -- " The captures is a comma-separated list of zero or more captures"
i'd like to see something that describes how to use lamda expressions productively
Here are a couple of examples.
it actually tells which variables will be made available to the function when it runs (it 'captures' those variables)
A lambda can only be converted to a function pointer if it does not capture any variable.
