Hello! I have to make this simple project but I have a big problem: the accelerometer in the picture (5 pins, power supply plus the 3 axes) is impossible to find, so I have bought a very common ADXL345 like this one.
Now, my problem is that I don't know how to connect it with the Arduino Uno board. Which accelerometer pins should go to the A0, A2 and A4 arduino pins? Or how do I need to modify the code below in order to use the ADXL345 accelerometer? It should be a minimal change in the code, one that a noob kid is supposed to be able to make.
THANK YOU!
pinMode(A0, INPUT);
pinMode(A2, INPUT);
pinMode(A4, INPUT);
pinMode(12, OUTPUT);
int x = analogRead(A0);
int y = analogRead(A2);
int z = analogRead(A4);
The ADXL337 is a chip with 3 analog outputs as the instructable seems to use.
The ADXL345 is an accelerometer with digital output, so it cannot be used with the posted code.
Thank you very much, now I see. Then could somebody please help me with a few code lines to be added to the code below? I have tested it and it works fine, I just need to trigger the pin 12 (a buzzer) when the ADXL345 records vibrations.
Thank you!
