Please help me About ICMP Ping
hello all friends
I arduino user from thailand. I am a newbie about arduino ( and C++ ) I use Eternet shield "ENC28j60" + Arduino board "ATmega328"
Now I try to programming command MCU send ICMP echo request from destination IP and Check Replay from Destination but not work...
All my friend please help me how to resolve problem please see below code where is wrong why not work. when i compile this code have error message "'class EtherShield has no member named 'ES_packetloop_icmp_checkreply'" but when i open files EtherShield.h I can see this class...
plese help me for this topic
  1. how to send icmp echo ping request to destination ip ( please show exam code )
  2. how to check replya echo icmp from destination ip ( please show exam code )
============ My Source Code =====
#include "etherShield.h"
#define INPUT_PIN 0
static uint8_t mymac[6] = {
0x54,0x55,0x58,0x10,0x00,0x25};
static uint8_t myip[4] = {
172,31,141,100};
static uint8_t destip[4] = {172,30,15,135};
static uint8_t websrvip[4] = {
172,30,15,135};
#define WEBSERVER_VHOST "twitter.com"
static uint8_t gwip[4] = {
172,31,140,1};
#define MYWWWPORT 80
static volatile uint8_t start_web_client=0; // 0=off but enabled, 1=send tweet, 2=sending initiated, 3=twitter was sent OK, 4=diable twitter notify
static uint8_t contact_onoff_cnt=0;
static uint8_t web_client_attempts=0;
static uint8_t web_client_sendok=0;
static uint8_t resend=0;
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 200; // the debounce time, increase if the output flickers
#define BUFFER_SIZE 250
#define DATE_BUFFER_SIZE 30
static char datebuf[DATE_BUFFER_SIZE]="none";
static uint8_t buf[BUFFER_SIZE+1];
EtherShield es=EtherShield();
int ledPin13 = 13;
void setup(){
pinMode(ledPin13, OUTPUT);
/initialize enc28j60/
es.ES_enc28j60Init(mymac);
//init the ethernet/ip layer:
es.ES_init_ip_arp_udp_tcp(mymac,myip,MYWWWPORT);
// init the web client:
es.ES_client_set_gwip(gwip); // e.g internal IP of dsl router
es.ES_client_set_wwwip(websrvip);
void loop(){
uint16_t dat_p;
int8_t cmd;
start_web_client=1;
// send icmp ping
es.ES_client_icmp_request(buf,destip);
delay(2000);
// end send icmp ping
dat_p=es.ES_packetloop_icmp_checkreply(buf,es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf));
//dat_p=es.ES_packetloop_icmp_tcp(buf,es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf));
if(dat_p==0){
digitalWrite(ledPin13, LOW);
delay(2000);
if(dat_p!=0)
digitalWrite(ledPin13, HIGH);
delay(2000);
delay(5000);
Best Regards for All my friends
Newbie Arduino From THAILAND
No body can help me :-/
I went to this site:
http://www.nuelectronics.com/estore/index.php?main_page=project_eth
and downloaded the etherShield library. I opened the etherShield.h file there:
  EHTERSHIELD_H library for Arduino etherShield
  Copyright (c) 2008 Xing Yu.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifndef ETHERSHIELD_H
#define ETHERSHIELD_H
#include <inttypes.h>
#include "enc28j60.h"
#include "ip_arp_udp_tcp.h"
#include "net.h"
class EtherShield
  public:
        EtherShield();
        uint16_t ES_fill_tcp_data_p(uint8_t *buf,uint16_t pos, const prog_char *progmem_s);
        uint16_t ES_fill_tcp_data(uint8_t *buf,uint16_t pos, const char *s);
            void ES_enc28j60Init(uint8_t* macaddr);
            void ES_enc28j60clkout(uint8_t clk);
            void ES_enc28j60PhyWrite(uint8_t address, uint16_t data);
            uint16_t ES_enc28j60PacketReceive(uint16_t len, uint8_t* packet);
            void ES_init_ip_arp_udp_tcp(uint8_t *mymac,uint8_t *myip,uint8_t wwwp);
            uint8_t ES_eth_type_is_arp_and_my_ip(uint8_t *buf,uint16_t len);
            void ES_make_arp_answer_from_request(uint8_t *buf);
            uint8_t ES_eth_type_is_ip_and_my_ip(uint8_t *buf,uint16_t len);
            void ES_make_echo_reply_from_request(uint8_t *buf,uint16_t len);
            void ES_make_tcp_synack_from_syn(uint8_t *buf);
            void ES_init_len_info(uint8_t *buf);
            uint16_t ES_get_tcp_data_pointer(void);
            void ES_make_tcp_ack_from_any(uint8_t *buf);
            void ES_make_tcp_ack_with_data(uint8_t *buf,uint16_t dlen);
            // new web client functions
            void ES_make_arp_request(uint8_t *buf, uint8_t *server_ip);
            uint8_t ES_arp_packet_is_myreply_arp ( uint8_t *buf );
            void ES_tcp_client_send_packet(uint8_t *buf,uint16_t dest_port, uint16_t src_port, uint8_t flags, uint8_t max_segment_size,
      uint8_t clear_seqck, uint16_t next_ack_num, uint16_t dlength, uint8_t *dest_mac, uint8_t *dest_ip);
            uint16_t ES_tcp_get_dlength( uint8_t *buf );
#endif
Perhaps it's a poor eyesight problem, but I don't see a member called ES_packetloop_icmp_checkreply.
So, where did you get YOUR library from?
in update version ( include twitter.h ) have class icmp_request and replay please see this below
#include "ip_config.h"
#include "net.h"
class EtherShield
public:
EtherShield();
uint8_t ES_enc28j60linkup(void);
void ES_init_ip_arp_udp_tcp(uint8_t *mymac,uint8_t *myip,uint16_t port);
// for a UDP server:
// return 0 to just continue in the packet loop and return the position
// of the tcp data if there is tcp data part
uint16_t ES_packetloop_icmp_tcp(uint8_t *buf,uint16_t plen);
// functions to fill the web pages with data:
// send data from the web server to the client:
void ES_www_server_reply(uint8_t *buf,uint16_t dlen);
// -- client functions --
#if defined (WWW_client) || defined (NTP_client)
uint8_t ES_client_store_gw_mac(uint8_t *buf, uint8_t *gwipaddr);
void ES_client_set_gwip(uint8_t *gwipaddr);
void ES_client_set_wwwip(uint8_t *wwwipaddr);
void ES_client_arp_whohas(uint8_t *buf,uint8_t *ip_we_search);
#endif
#define HTTP_HEADER_START ((uint16_t)TCP_SRC_PORT_H_P+(buf[TCP_HEADER_LEN_P]>>4)*4)
#ifdef WWW_client
// ----- http get
void ES_client_browse_url(prog_char *urlbuf, char *urlbuf_varpart, prog_char *hoststr,void (*callback)(uint8_t,uint16_t));
// The callback is a reference to a function which must look like this:
// void browserresult_callback(uint8_t statuscode,uint16_t datapos)
// statuscode=0 means a good webpage was received, with http code 200 OK
// statuscode=1 an http error was received
// statuscode=2 means the other side in not a web server and in this case datapos is also zero
// ----- http post
// client web browser using http POST operation:
// additionalheaderline must be set to NULL if not used.
// method should be used if default POST to be overridden set NULL for dfault
// postval is a string buffer which can only be de-allocated by the caller
// when the post operation was really done (e.g when callback was executed).
// postval must be urlencoded.
void ES_client_http_post(prog_char *urlbuf, prog_char *hoststr, prog_char *additionalheaderline, prog_char *method, char *postval,void (*callback)(uint8_t,uint16_t));
#endif
#ifdef NTP_client
void ES_client_ntp_request(uint8_t *buf,uint8_t *ntpip,uint8_t srcport);
uint8_t ES_client_ntp_process_answer(uint8_t *buf,uint32_t *time,uint8_t dstport_l);
#endif
// you can find out who ping-ed you if you want:
void ES_register_ping_rec_callback(void (*callback)(uint8_t *srcip));
#ifdef PING_client
void ES_client_icmp_request(uint8_t *buf,uint8_t *destip);
// you must loop over this function to check if there was a ping reply:
uint8_t ES_packetloop_icmp_checkreply(uint8_t *buf,uint8_t *ip_monitoredhost);
#endif // PING_client#ifdef WOL_client
void ES_send_wol(uint8_t *buf,uint8_t *wolmac);
#endif // WOL_client
#ifdef FROMDECODE_websrv_help
uint8_t ES_find_key_val(char *str,char *strbuf, uint8_t maxlen,char *key);
void ES_urldecode(char *urlbuf);
#endif // FROMDECODE_websrv_help
#ifdef URLENCODE_websrv_help
void ES_urlencode(char *str,char *urlbuf);
#endif // URLENCODE_websrv_help
uint8_t ES_parse_ip(uint8_t *bytestr,char *str);
void ES_mk_net_str(char *resultstr,uint8_t *bytestr,uint8_t len,char separator,uint8_t base);
#endif
Anyway, Please help me how to call class to work
So, did you use
#define PING_client
anywhere?
Please learn how to post code properly. See that # on the top row when you are creating or replying to a post? Use it!
