Please, help me find sensor for vital signs monitoring
Hello, I'm a beginner and I planned to make a vital signs monitoring Using Arduino Uno r3 as the mcu and sensors. I'm using these sensor, GY90 for temperature, max30100 for heart rate and oxygen level, and I'm thinking of adding AD8232 for ECG.
I want to atleast measure 8 vital signs, and the vitals signs should be measured using only through hand/fingertips., please recommend me sensors that I can use.. Thank you
The GY90 and MAX30100 are sensors
All you need for the AD8232 are electrodes that you stick on your hands.
Are there other sensors that I can use? Aside from what I've mention? I needed atleast 8 vitals signs to measure and using max30100, GY90 and ecg could only measure at the very least 5 sensors. I needed 3 more other sensor. Thank you
I'm not an MD and I don't know if the human body even has 8 Vital signs.
However you can also measure blood pressure.
Well, is there a sensor that can measure blood pressure/glucose level?
Off hand I do not know.
I don't think glucose is considered a vital sign.
