Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 1010 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\NetHunter\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\NetHunter\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\NETHUN~1\AppData\Local\Temp\arduino_build_732475/sketch_mar16a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\NetHunter\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xaf
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
