Problem with the UNO r3
项目使用了 924 字节,占用了 (2%) 程序存储空间。最大为 32256 字节。
全局变量使用了9字节,(0%)的动态内存,余留2039字节局部变量。最大为2048字节。
F:\编程\Arduino\Arduino1.8.19\Arduino\hardware\tools\avr/bin/avrdude -CF:\编程\Arduino\Arduino1.8.19\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\HUA\AppData\Local\Temp\arduino_build_498067/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "F:\���\Arduino\Arduino1.8.19\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xce
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
How to solve this problem?it happens on the UNO R3
         Using Port                    : COM7
how to solve this problem?
@wang963852, do not cross-post. Threads merged.
@wang963852
This question is asked here five times a day, use the forum search
Hi @wang963852. Please try this experiment and then report back with the results:
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
  1. Connect the Arduino board to your computer with a USB cable.
  2. Press and release the button on the Arduino board that is marked "RESET".
Now please reply here on the forum thread with the answer to the following question:
  • Did you see the "L" LED blink multiple times quickly immediately after you released the "RESET" button?
Hi Friend, yes, the L light blink three times quickly.
This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
  1. Disconnect the USB cable of the Arduino board from your computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Take note of the ports, if any, listed in the menu.
  4. Close the Tools menu.
    :exclamation: The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Connect the Arduino board to your computer with a USB cable.
  6. Select Tools > Port from the Arduino IDE menus.
  7. Wait a few seconds for Arduino IDE to recognize the connection.
If a new port appeared at the last step, that is the port of your Arduino board. Select that port from the menu and try uploading again.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, please reply here on this forum thread with the answers to the following questions:
  • Did you see a port appear in the menu after you performed the instructions?
  • If a port did appear, but the upload to that port still failed, what was the error message from the upload?
yes, i did it as you said, but this still happen when i burn the bootloader. the port is right and the computer can find this port , but the board could not pass the loopback test . so is the serial port normal?
         System wide configuration file is "C:\Users\xingy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
烧录引导程序出错。
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
it shows this then ,could not born to the old board.
