Hi,for my project iam using an acs712 20a current sensor and dht11 temperature and ambient sensor. but in the code its is acs723 and DS18B20 temperature sensor.
so can someone help me editing the code.iam using esp32 module
This is the code below:
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <DallasTemperature.h>
#include <OneWire.h>
#include "Wire.h"
#include <WiFi.h>
#define BLYNK_PRINT Serial
#include <BlynkSimpleEsp32.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define INPUT_VOLTAGE_SENSE_PIN 34
#define INPUT_CURRENT_SENSE_PIN 35
#define TEMP_SENSE_PIN 4
#define VOLTAGE_SCALE 7.911 // R1+R2 / R2 // ( 47K + 6.8K ) / 6.8K
#define CURRENT_SCALE 1.5 // R4+R5 / R5 // ( 1K + 2K ) / 2K
double mVperAmp = 200; //Sensityvit of the sensor // use 100 for 20A Module and 66 for 30A Module
double ACSoffset = 514; // Ideally it should be ( 0.1 x Vcc ) // measured value is 514mV
unsigned long last_time =0;
unsigned long current_time =0;
float power =0 ; // Power in Watt
float energy =0 ; // Emergy in Watt-Hour
float tempC=0; // temperaure in Celcius
//float tempF = 0; temperature in F
float saving=0; // cost saving
WiFiClient client;
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// GPIO where the DS18B20 is connected to
const int oneWireBus = 2;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(TEMP_SENSE_PIN);
DallasTemperature sensors(&oneWire);
//========================= Variables for wifi server setup =============================
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "XXXX"; // WiFi Router ssid
char pass[] = "XXXX"; // WiFi Router password
// copy it from the mail received from Blynk
char auth[] = "XXXX";
//========================= Setup Function ================================================
Blynk.begin(auth, ssid, pass);
sensors.begin();
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;);
display.clearDisplay();
display.setTextColor(WHITE);
display.display();
//========================= Loop Function ================================================
// read voltage and current
float voltage = abs( return_voltage_value(INPUT_VOLTAGE_SENSE_PIN)) ;
float current = abs( return_current_value(INPUT_CURRENT_SENSE_PIN)) ;
// read temperature from DS18B20
sensors.requestTemperatures(); // get temperatures
tempC = sensors.getTempCByIndex(0);
//tempF = sensors.getTempFByIndex(0);
// Calculate power and energy
power = current * voltage ; // calculate power in Watt
last_time = current_time;
current_time = millis();
energy = energy + power *(( current_time -last_time) /3600000.0) ; // calculate power in Watt-Hour // 1 Hour = 60mins x 60 Secs x 1000 Milli Secs
saving = 6.5 * ( energy /1000 ); // 6.5 is cost per kWh // used just for example
// ================= Display Data on Serial Monitor ================================================
/* Serial.print("Voltage: ");
Serial.println(voltage);
Serial.print("Current: ");
Serial.println(current);
Serial.print("Power: ");
Serial.println(power);
Serial.print("Energy: ");
Serial.println(energy);
Serial.print("Temp: ");
Serial.println(tempC);
// ================= Display Data on OLED Display ================================================
// Display Solar Panel Voltage
display.setTextSize(1);
display.setCursor(10, 10);
display.print(voltage,1);
display.print(" V");
// Display Solar Panel Current
display.setCursor(70, 10);
if (current >0 && current < 1 )
display.print(current*1000,0);
display.print(" mA");
display.print(current,2);
display.print(" A");
// Display Solar Panel Power in Watt
display.setTextSize(2);
display.setCursor(10,25);
display.print(power);
display.print(" W");
// Display Energy Generated by the Solar Panel
display.setCursor(10,45);
if ( energy >= 1000 )
display.print(energy/1000,3);
display.print(" kWh");
display.print(energy,1);
display.print(" Wh");
display.display();
// ================= Display Data on Blynk App ================================================
Blynk.run();
Blynk.virtualWrite(0, voltage ); // virtual pin 0
Blynk.virtualWrite(1, current ); // virtual pin 1
Blynk.virtualWrite(2, power); // virtual pin 2
Blynk.virtualWrite(3,energy/1000);// virtual pin 3
Blynk.virtualWrite(4,tempC ); // virtual pin 4
Blynk.virtualWrite(5,saving); // virtual pin 4
//delay(1000);
//========================= Function to Calculate Solar Panel Voltage ===================================
double return_voltage_value(int pin_no)
double tmp = 0;
double ADCVoltage = 0;
double inputVoltage = 0;
double avg = 0;
for (int i = 0; i < 100; i++)
tmp = tmp + analogRead(pin_no);
avg = tmp / 100;
ADCVoltage = ((avg * 3.3) / (4095)) + 0.184 ; // 0.184 is offset adjust by heat and try
inputVoltage = ADCVoltage * VOLTAGE_SCALE;
return inputVoltage;
//========================= Function to Calculate Solar Panel Current ===================================
double return_current_value(int pin_no)
double tmp = 0;
double avg = 0;
double Amps = 0;
for (int z = 0; z < 150; z++)
avg = tmp / 150;
ADCVoltage = ((avg*3331) / 4095); // Gets you mV
Amps = ((ADCVoltage * CURRENT_SCALE - ACSoffset ) / mVperAmp); // 1.5 is the scaling for voltage divider
return Amps;
}<br>
Work on each component using example code before you try to build a project. Once you master each component by itself, putting together a project will be much easier. If someone just fixes your code for you you will never develop the skils to maintain, improve or change aspects of your project.
i tried a lot with this project initially the code had sh1106 oled and my oled was ssd1306 i changed it into this and it is now working fine i couldn't find ds18b20 .so if anybody can help me please help so that i would know how to solve it
Bro for me i am doing a small solar setup in my home for that i am using a pwm charger and it doesn't have an display so thats why i am doing this as alternative
