Hi there,
I am trying to playback frequencies stored in EEPROM, however there is a low frequency constant background noise in the playback. Is this a software or hardware problem?
Thanks in advance.
Here is my code:
#include <EEPROM.h>
#include "pitches.h"
#define speaker A5
#define record_button 3
#define play_button 5
#define record_led 2
#define play_led 4
#define melody_button A0
int customVar;
int eeAddress = 0;
int eeAddressplay = 0;
const int inPot = A1; //potentiometer to change octaves (8 octaves in total)
byte octave;
byte tone_out; // specifies elements in melody array
int tone_key; // frequency of key
boolean silence; // silence variable is either true or false
int maxNumber = 500;
byte time = 20; //increase, teach about sampling, break data into discrete time segments, memory
byte buttons[] = {6,7,8,9,10,11,12,13};
int saveSounds[500];
int saveNumber = 0;
byte melody1[8] = {
NOTE_C1 , NOTE_D1, NOTE_E1, NOTE_F1, NOTE_G1, NOTE_A1, NOTE_B1, NOTE_C2};
byte melody2[8] = {
NOTE_C2 , NOTE_D2, NOTE_E2, NOTE_F2, NOTE_G2, NOTE_A2, NOTE_B2, NOTE_C3};
int melody3[8] = {
NOTE_C3 , NOTE_D3, NOTE_E3, NOTE_F3, NOTE_G3, NOTE_A3, NOTE_B3, NOTE_C4};
int melody4[8] = {
NOTE_C4 , NOTE_D4, NOTE_E4, NOTE_F4, NOTE_G4, NOTE_A4, NOTE_B4, NOTE_C5};
int melody5[8] = {
NOTE_C5 , NOTE_D5, NOTE_E5, NOTE_F5, NOTE_G5, NOTE_A5, NOTE_B5, NOTE_C6};
int melody6[8] = {
NOTE_C6 , NOTE_D6, NOTE_E6, NOTE_F6, NOTE_G6, NOTE_A6, NOTE_B6, NOTE_C7};
int melody7[8] = {
NOTE_C7 , NOTE_D7, NOTE_E7, NOTE_F7, NOTE_G7, NOTE_A7, NOTE_B7, NOTE_C8};
//PIANO FUNCTION
void freePlay() // piano function which plays 8 octaves (8 octaves in total, 8 keys per octave)
octave = map(analogRead(inPot),0,1023,1,7); // analogRead: 0-5V input voltage maps to integer values 0-1023
// integer values 0-1023 maps to 1-8
if (digitalRead(buttons[0]) == HIGH) {
tone_out = 0; // if the first button is pressed, tone_out = 0 and silence = false
silence = false; // skips to if (silence == false) line
else if (digitalRead(buttons[1]) == HIGH) {
tone_out = 1;
silence = false;
else if (digitalRead(buttons[2]) == HIGH) {
tone_out = 2;
silence = false;
else if (digitalRead(buttons[3]) == HIGH) {
tone_out = 3;
silence = false;
else if (digitalRead(buttons[4]) == HIGH) {
tone_out = 4;
silence = false;
else if (digitalRead(buttons[5]) == HIGH) {
tone_out = 5;
silence = false;
else if (digitalRead(buttons[6]) == HIGH) {
tone_out = 6;
silence = false;
else if (digitalRead(buttons[7]) == HIGH) {
tone_out = 7;
silence = false;
else {
silence = true; // if none of the if/elseif statements are true, execute silence = true
switch(octave) // depending on which octave is selected (1-8), the corresponding switch case statement is executed
case 1:
tone_key = melody1[tone_out]; break;
case 2:
tone_key = melody2[tone_out]; break;
case 3:
tone_key = melody3[tone_out]; break;
case 4:
tone_key = melody4[tone_out]; break;
case 5:
tone_key = melody5[tone_out]; break;
case 6:
tone_key = melody6[tone_out]; break;
case 7:
tone_key = melody7[tone_out]; break;
tone(speaker,tone_key); // Arduino inbuilt tone function generates a square wave of the specified frequency
} // at 50% duty cycle on the speaker pin
else {
noTone(speaker); // wave continues until a call to noTone()
delay (5); } // 5 millisecond delay
//SETUP FUNCTION
void setup() // setup Arduino pins as input or output
for(int i = 0; i < 8; i++)
pinMode(buttons[i], INPUT);
pinMode(speaker, OUTPUT);
pinMode(melody_button, INPUT);
pinMode(record_led, OUTPUT);
pinMode(play_led, OUTPUT);
pinMode(inPot, INPUT);
//MAIN CODE
freePlay();
//RECORD
if (digitalRead(record_button) == HIGH) {
digitalWrite(record_led, HIGH);
for(int i = 0; i < maxNumber ; i++) {
tone_out = 0;
silence = false;
tone_out = 1;
silence = false;
tone_out = 2;
silence = false;
tone_out = 3;
silence = false;
tone_out = 4;
silence = false;
tone_out = 5;
silence = false;
tone_out = 6;
silence = false;
tone_out = 7;
silence = false;
else {
silence = true;
tone_key = 0;
if (silence == false) {
switch(octave) {
case 1: tone_key = melody1[tone_out]; break;
case 2: tone_key = melody2[tone_out]; break;
case 3: tone_key = melody3[tone_out]; break;
case 4: tone_key = melody4[tone_out]; break;
case 5: tone_key = melody5[tone_out]; break;
case 6: tone_key = melody6[tone_out]; break;
case 7: tone_key = melody7[tone_out]; break;
delay(time);
else {
noTone(speaker);
tone_key = 0;
delay (time);
saveSounds[saveNumber] = tone_key;
saveNumber++;
if (digitalRead(play_button) == HIGH) {
digitalWrite(record_led, LOW);
tone(speaker, 700);
delay(200);
noTone(speaker);
for (int i = 0; i<500; i++) {
EEPROM.put(eeAddress,saveSounds[i]);
eeAddress = eeAddress + 2;
//PLAYBACK
if(digitalRead(play_button) == HIGH) {
digitalWrite(play_led, HIGH);
for(int i = 0; i < maxNumber; i++) {
EEPROM.get(eeAddressplay,customVar);
tone(speaker,customVar);
eeAddressplay = eeAddressplay + 2;
delay(time);
Serial.print(customVar);
noTone(speaker);
digitalWrite(play_led,LOW);
