Please review this circuit diagram
The DC motors are used to move the truck
Still missing the labels, but quite easy to follow what you are up to. :+1:
If you want a review, we need component data and labels.
Why is espcam not fed from buck converter?
Thanks of the circuit attempt.
Please try and hand draw it and include pin numbers/names.
Different colour wires do not help either, just black and white will do.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
@build_1971 ESP32 CAM is powered from buck converter as its voltage regulator sheet says it supports 6 - 20v, as to not face any current problems.
@TomGeorge
This is HG7881 Module I am planning to buy
About the same specs as an L293D.
Only for thumbnail-sized brushed DC motors, and not suitable for most modern stepper motors.
Leo..
5V pin of ESP connected to 7.4V, should be 5V converter.
PS, schematic o follow.
Can you please post links to;
spec/data of the motors
spec data of pump
spec data of flame sensor
I agree with @Wawa not the ideal efficient motor driver.
The 7881 has 9110 drivers in it.
Specs 9110;
For 9V supply you loose nearly 2V in the IC.
Following proposed @axlnneac schematic.
@Wawa I am planning to use these motors
@TomGeorge I did not understand what you are trying to say.
@TomGeorge
Motors specs
Pump Specs
Flame Sensor specs
I can also use an I2C GPIO Expander, so I don't think there will be any pin shortages right?
You will be loosing about 1/3 of your battery/motor power to heat/inefficiency of the 7881 which uses L9110 driver ICs.
PS. Is that schematic I posted, what you are at the moment proposing to make?
Thanks @axlnneac
Flame Sensor;
image image
Submersible Pump;
image image
DC Motor;
image image
Tom... :smiley: :+1: :coffee: :australia:
Yes sir
Yes
