Pls help Compilation error: 'myStepper' was not declared in this scope
Can anyone pls help in using stepper.h and its included pls help me.
Best you read the intro on how to post here.
Bare minimum would be a copy of your code ( in code brackets as required) and a circuit diagram of what you have in front of you. (Not Fritzing)
Anything less becomes" I have a car and it's broken...what's wrong with it?"
oh. ok ty blue jets
Code:
#include <Servo.h>
#include <Stepper.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
int Forward;
const int trigPin = 5;
const int echoPin = 6;
const int SW_pin = 2; // digital pin connected to switch output
const int X_pin = A0; // analog pin connected to X output
const int Y_pin = A1; // analog pin connected to Y output
const int stepsPerRevolution = 2048;  // change this to fit the number of steps per revolution
const int rolePerMinute = 15;         // Adjustable range of 28BYJ-48 stepper is 0~17 rpm
float duration, distance;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(11, OUTPUT);
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(SW_pin, INPUT);
  digitalWrite(SW_pin, HIGH);
  Stepper.setSpeed(rolePerMinute)
  // initialize the serial port:
  Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Servo
  //val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  //val = map(val, 0, 1023, 0, 180);     // scale it to use it with the servo (value between 0 and 180)
  val = (val + 2);
  myservo.write(val);                  // sets the servo position according to the scaled value
  if (val > 175) {
    val = -40;
  //Path Finding Here
  if (distance > 23) {
    Forward = 'true';
  else if (distance < 23) {
    Forward = 'false';
  else {
    Serial.print('ERROR');
  // JoyStick
  int X = A1;
  int Y = A2;
  duration = pulseIn(echoPin, HIGH);
  distance = (duration*.0343)/2;
  Serial.print("Switch:  ");
  Serial.print(digitalRead(SW_pin));
  Serial.print("   ");
  Serial.print("X-axis: ");
  Serial.print(analogRead(X_pin));
  Serial.print("   ");
  Serial.print("Y-axis: ");
  Serial.println(analogRead(Y_pin));
  Serial.print("Distance: ");
  Serial.println(distance);
  Serial.print("Motor:");
  Serial.print(val);
  Serial.print("   ");
  //Path Finding
  if (Forward = 'true') {
  else if (Forward = 'false') {
  delay(20);
Try to egnore the other stuff :slight_smile:
Should be global ‘scope’, not local within setup()
ok ill try that ty
it works!!! tysm!!!!!!!
You will also have to fix some of those warnings:
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:50:15: warning: character constant too long for its type
     Forward = 'true';
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:53:15: warning: character constant too long for its type
     Forward = 'false';
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:56:18: warning: character constant too long for its type
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:78:17: warning: character constant too long for its type
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:80:22: warning: character constant too long for its type
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino: In function 'void setup()':
sketch_jun09a:28:10: error: expected unqualified-id before '.' token
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino: In function 'void loop()':
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:78:15: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:80:20: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:59:7: warning: unused variable 'X' [-Wunused-variable]
   int X = A1;
/tmp/arduino_modified_sketch_739258/sketch_jun09a.ino:60:7: warning: unused variable 'Y' [-Wunused-variable]
   int Y = A2;
     Forward = 'true';
Forward is an int, you can't assign some form of text to it, only one character. Make forward a bool variable and assign true or false to it.
Single = for assigment, double == for compare.
I suggest that you set Compiler warnings to all in File/Preferences.
ok ty
