PLX-DAQ is not logging data
I'm currently attempting to play around with the new PLX-DAQ v2.11 and am using this simple example:
int pot= A0;
  Serial.println("CLEARDATA");
  Serial.println("LABEL, Time, Started Time, Date, Analog Value, POT%");
  Serial.println("RESETTIMER");
  int pot_val = analogRead(pot);
  int pot_percentage = map(pot_val, 0, 1023, 0, 100);
  Serial.print("DATA, TIME, TIMER, DATE,");
  Serial.print(pot_val);
  Serial.print(" ,");
  Serial.print(pot_percentage);
  Serial.println(" ,");
  delay(1500);
I see the data coming up in the DAQ debug window, but it is not logging in the excel cells. I have selected the correct COM port, matched the baud rate, and have hit the connect button. I'm not sure what else I am missing.
Always start with one of the provided code examples and make sure that works. If not, check the PLX-DAQ thread on this forum to see if someone has already had the problem, and/or post on that thread. The author does check in.
