PMW3389 + MLX90393 combined, issues on Pro Micro
Using a pro micro.
The separate sketches work fine. When I combine them into one, every readout of the MLX (i2c) interrupts the PMW sensor.
So when I set the update interval of the MLX to 1000ms, I get:
  1. smooth mouse movement for 1s,
  2. it stops for a fraction of a second, when I get a new readout from the MLX
  3. jumps to another position
  4. goto 1
So I'm wondering if this is an issue with the pro micro that can't handle both i2c and spi interfaces simultaneously and continuously?
Or should I put both on the SPI bus?
Here is the code, which is basically a mashup from the Adafruit MLX90393 and a PMW3389 sketch from github.
#include <Keyboard.h>
#include <Wire.h>
#include <SPI.h>
#include <avr/pgmspace.h>
#include "Adafruit_MLX90393.h"
#include <AdvMouse.h>
#define MOUSE_BEGIN AdvMouse.begin()
#define MOUSE_PRESS(x) AdvMouse.press_(x)
#define MOUSE_RELEASE(x) AdvMouse.release_(x)
unsigned long lastUpdatePMW = 0;
unsigned long lastUpdateMLX = 0;
const long PMWUpdateInterval = 1;     //ms for PMW sensor
const long MLXUpdateInterval = 1000;  //ms for MLX sensor
Adafruit_MLX90393 sensor = Adafruit_MLX90393();
//#define MLX90393_CS 10
// Configurations
// Variables to track angular change
float lastAngle = 0;
float cumulativeAngle = 0;  // Tracks total rotation
// Define thresholds for scrolling
float scrollThreshold = 20;  // Angular difference threshold to trigger scroll
int scrollStep = 3;          // Amount to scroll per threshold exceeded
// The default CPI value should be in between 100 -- 12000
#define CPI 8000
#define DEBOUNCE 10  //unit = ms.
//Set this to a pin your buttons are attached
#define NUMBTN 4
#define Btn1_Pin 4  // left button
#define Btn2_Pin 5  // right button
#define Btn4_Pin 6  // middle button
#define Btn8_Pin 7  // Mission control F3
// Registers
#define Product_ID 0x00
#define Revision_ID 0x01
#define Motion 0x02
#define Delta_X_L 0x03
#define Delta_X_H 0x04
#define Delta_Y_L 0x05
#define Delta_Y_H 0x06
#define SQUAL 0x07
#define Raw_Data_Sum 0x08
#define Maximum_Raw_data 0x09
#define Minimum_Raw_data 0x0A
#define Shutter_Lower 0x0B
#define Shutter_Upper 0x0C
#define Ripple_Control 0x0D
#define Resolution_L 0x0E
#define Resolution_H 0x0F
#define Config2 0x10
#define Angle_Tune 0x11
#define Frame_Capture 0x12
#define SROM_Enable 0x13
#define Run_Downshift 0x14
#define Rest1_Rate_Lower 0x15
#define Rest1_Rate_Upper 0x16
#define Rest1_Downshift 0x17
#define Rest2_Rate_Lower 0x18
#define Rest2_Rate_Upper 0x19
#define Rest2_Downshift 0x1A
#define Rest3_Rate_Lower 0x1B
#define Rest3_Rate_Upper 0x1C
#define Observation 0x24
#define Data_Out_Lower 0x25
#define Data_Out_Upper 0x26
#define SROM_ID 0x2A
#define Min_SQ_Run 0x2B
#define Raw_Data_Threshold 0x2C
#define Control2 0x2D
#define Config5_L 0x2E
#define Config5_H 0x2F
#define Power_Up_Reset 0x3A
#define Shutdown 0x3B
#define Inverse_Product_ID 0x3F
#define LiftCutoff_Cal3 0x41
#define Angle_Snap 0x42
#define LiftCutoff_Cal1 0x4A
#define Motion_Burst 0x50
#define SROM_Load_Burst 0x62
#define Lift_Config 0x63
#define Raw_Data_Burst 0x64
#define LiftCutoff_Cal2 0x65
#define LiftCutoff_Cal_Timeout 0x71
#define LiftCutoff_Cal_Min_Length 0x72
#define PWM_Period_Cnt 0x73
#define PWM_Width_Cnt 0x74
const int ncs = 10;   // This is the SPI "slave select" pin that the sensor is hooked up to
const int reset = 8;  // Optional
int Btn_pins[NUMBTN] = { Btn1_Pin, Btn2_Pin, Btn4_Pin, Btn8_Pin };
bool Btns[NUMBTN] = { false, false, false, false };        // button state indicator
uint8_t Btn_buffers[NUMBTN] = { 0xFF, 0xFF, 0xFF, 0xFF };  // button debounce buffer
char Btn_keys[NUMBTN] = { MOUSE_LEFT, MOUSE_RIGHT, MOUSE_MIDDLE, KEY_F3 };
byte initComplete = 0;
bool inBurst = false;   // in busrt mode
bool reportSQ = false;  // report surface quality
int16_t dx, dy;
unsigned long lastTS;
unsigned long lastButtonCheck = 0;
unsigned long curTime;
//Be sure to add the SROM file into this sketch via "Sketch->Add File"
extern const unsigned short firmware_length;
extern const unsigned char firmware_data[];
  MLXsetup();
  pinMode(ncs, OUTPUT);
  pinMode(reset, INPUT_PULLUP);
  pinMode(Btn1_Pin, INPUT_PULLUP);
  pinMode(Btn2_Pin, INPUT_PULLUP);
  pinMode(Btn4_Pin, INPUT_PULLUP);
  pinMode(Btn8_Pin, INPUT_PULLUP);
  SPI.begin();
  SPI.setDataMode(SPI_MODE3);
  SPI.setBitOrder(MSBFIRST);
  //SPI.setClockDivider(4);
  Serial.println("ON");
  performStartup();
  dx = dy = 0;
  initComplete = 9;
  lastTS = micros();
  MOUSE_BEGIN;
void MLXsetup() {
  Wire.begin();      // Initialize I2C communication
  AdvMouse.begin();  // Initialize AdvMouse for scroll emulation
  while (!Serial) {
    delay(10);  // Wait for serial port to open
  Serial.println("Starting Adafruit MLX90393 Demo");
  // Initialize MLX90393 sensor using I2C
  if (!sensor.begin_I2C()) {
    Serial.println("No sensor found ... check your wiring?");
    while (1) {
      delay(10);  // If sensor is not found, keep waiting
  Serial.println("Found a MLX90393 sensor");
  // Configure the sensor settings
  sensor.setGain(MLX90393_GAIN_1X);                   // Set gain to 1x
  sensor.setResolution(MLX90393_X, MLX90393_RES_17);  // Set resolution for X axis
  sensor.setResolution(MLX90393_Y, MLX90393_RES_17);  // Set resolution for Y axis
  sensor.setResolution(MLX90393_Z, MLX90393_RES_16);  // Set resolution for Z axis
  sensor.setOversampling(MLX90393_OSR_1);             // Set oversampling rate
  sensor.setFilter(MLX90393_FILTER_1);                // Set filter to level 5
void MLXLoep() {
  float x, y, z;
  // Read data from MLX90393 sensor
  if (sensor.readData(&x, &y, &z)) {
    Serial.print("X: ");
    Serial.print(x, 4);
    Serial.print(" uT\t");
    Serial.print("Y: ");
    Serial.print(y, 4);
    Serial.print("Z: ");
    Serial.print(z, 4);
    Serial.println(" uT");
    // Calculate angle in the XY plane
    float angle = atan2(y, x) * 180.0 / PI;  // Convert radians to degrees
    // Calculate change in angle
    float deltaAngle = angle - lastAngle;
    lastAngle = angle;
    // Adjust for angular wrap-around
    if (deltaAngle > 180) deltaAngle -= 360;
    if (deltaAngle < -180) deltaAngle += 360;
    cumulativeAngle += deltaAngle;
    Serial.print("Cumulative Angle: ");
    Serial.println(cumulativeAngle);
    // Trigger scroll when cumulative angle change exceeds threshold
    if (cumulativeAngle > scrollThreshold) {
      AdvMouse.move(0, 0, scrollStep);  // Scroll up by scrollStep units using AdvMouse
      cumulativeAngle = 0;              // Reset cumulative angle after scrolling
    } else if (cumulativeAngle < -scrollThreshold) {
      AdvMouse.move(0, 0, -scrollStep);  // Scroll down by scrollStep units using AdvMouse
    Serial.println("Unable to read XYZ data from the sensor.");
  delay(20);  // Adjust delay for scroll speed responsiveness
void setCPI(int cpi) {
  unsigned cpival = cpi / 50;
  adns_com_begin();
  adns_write_reg(Resolution_L, (cpival & 0xFF));
  adns_write_reg(Resolution_H, ((cpival >> 8) & 0xFF));
  adns_com_end();
  Serial.print("Got ");
  Serial.println(cpi);
  Serial.print("Set cpi to ");
  Serial.println(cpival * 50);
void PMWLoep() {
  byte burstBuffer[12];
  unsigned long curTime = micros();
  unsigned long elapsed = curTime - lastTS;
  // Process button state (no delays, just checks)
  check_button_state();
  // Start burst mode only if it's not already started
  if (!inBurst) {
    adns_write_reg(Motion_Burst, 0x00);  // Start burst mode
    lastTS = curTime;
    inBurst = true;
  // Ensure this logic runs at the desired polling interval (e.g., 1ms)
  if (elapsed >= 1) {  // Polling interval > 0.5 ms
    adns_com_begin();
    SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE3));
    SPI.transfer(Motion_Burst);
    delayMicroseconds(35);  // Waits for tSRAD
    SPI.transfer(burstBuffer, 12);  // Read burst buffer
    delayMicroseconds(1);           // tSCLK-NCS for read operation is 120ns
    SPI.endTransaction();
    // Extract data from burstBuffer
    int motion = (burstBuffer[0] & 0x80) > 0;
    int surface = (burstBuffer[0] & 0x08) > 0;  // 0 if on surface, 1 if off surface
    int xl = burstBuffer[2];
    int xh = burstBuffer[3];
    int yl = burstBuffer[4];
    int yh = burstBuffer[5];
    int squal = burstBuffer[6];
    // Calculate X and Y motion
    int x = xh << 8 | xl;
    int y = yh << 8 | yl;
    // Invert axes if needed (adjust as necessary for your setup)
    dx -= y;
    dy -= x;
    adns_com_end();
    // Update mouse only if motion is detected
    if (AdvMouse.needSendReport() || motion) {
      AdvMouse.move(dx, dy, 0);
      dx = 0;
      dy = 0;
    // Update last timestamp for PMW sensor
    lastTS = curTime;
    // Command process routine
    if (Serial.available() > 0) {
      char c = Serial.read();
      switch (c) {
        case 'C':  // Set CPI
          int newCPI = readNumber();
          setCPI(newCPI);
  if (currentMillis - lastUpdatePMW >= PMWUpdateInterval) {
    lastUpdatePMW = currentMillis;
    // Read and process PMW sensor data
    PMWLoep();
  if (currentMillis - lastUpdateMLX >= MLXUpdateInterval) {
    lastUpdateMLX = currentMillis;
    // Read and process MLX sensor data
    MLXLoep();
// Button state checkup routine
void check_button_state() {
  // runs only after initialization
  if (initComplete != 9)
    return;
  unsigned long elapsed = curTime - lastButtonCheck;
  // Update at a period of 1/8 of the DEBOUNCE time
  if (elapsed < (DEBOUNCE * 1000UL / 8))
    return;
  lastButtonCheck = curTime;
  // Debounce
  for (int i = 0; i < NUMBTN; i++) {
    int btn_state = digitalRead(Btn_pins[i]);
    Btn_buffers[i] = Btn_buffers[i] << 1 | btn_state;
    if (!Btns[i] && Btn_buffers[i] == 0x00)  // button press stabilized
      MOUSE_PRESS(Btn_keys[i]);
      Btns[i] = true;
    } else if (Btns[i] && Btn_buffers[i] == 0xFF)  // button release stabilized
      MOUSE_RELEASE(Btn_keys[i]);
      Btns[i] = false;
unsigned long readNumber() {
  String inString = "";
  for (int i = 0; i < 10; i++) {
    while (Serial.available() == 0)
    int inChar = Serial.read();
    if (isDigit(inChar)) {
      inString += (char)inChar;
    if (inChar == '\n') {
      int val = inString.toInt();
      return (unsigned long)val;
  // flush remain strings in serial buffer
  while (Serial.available() > 0) {
    Serial.read();
  return 0UL;
//Firmware things//
void performStartup(void) {
  // hard reset
  adns_com_end();    // ensure that the serial port is reset
  adns_com_begin();  // ensure that the serial port is reset
  adns_write_reg(Shutdown, 0xb6);  // Shutdown first
  delay(300);
  adns_com_begin();  // drop and raise ncs to reset spi port
  delayMicroseconds(40);
  adns_com_end();
  adns_write_reg(Power_Up_Reset, 0x5a);  // force reset
  delay(50);                             // wait for it to reboot
  // read registers 0x02 to 0x06 (and discard the data)
  adns_read_reg(Motion);
  adns_read_reg(Delta_X_L);
  adns_read_reg(Delta_X_H);
  adns_read_reg(Delta_Y_L);
  adns_read_reg(Delta_Y_H);
  // upload the firmware
  adns_upload_firmware();
  delay(10);
  Serial.println("Optical Chip Initialized");
void adns_com_begin() {
  digitalWrite(ncs, LOW);
void adns_com_end() {
  digitalWrite(ncs, HIGH);
byte adns_read_reg(byte reg_addr) {
  adns_com_begin();
  // send adress of the register, with MSBit = 0 to indicate it's a read
  SPI.transfer(reg_addr & 0x7f);
  delayMicroseconds(35);  // tSRAD
  // read data
  byte data = SPI.transfer(0);
  adns_com_end();
  delayMicroseconds(19);  //  tSRW/tSRR (=20us) minus tSCLK-NCS
  return data;
void adns_write_reg(byte reg_addr, byte data) {
  adns_com_begin();
  //send adress of the register, with MSBit = 1 to indicate it's a write
  SPI.transfer(reg_addr | 0x80);
  //sent data
  SPI.transfer(data);
  delayMicroseconds(20);  // tSCLK-NCS for write operation
  adns_com_end();
  delayMicroseconds(100);  // tSWW/tSWR (=120us) minus tSCLK-NCS. Could be shortened, but is looks like a safe lower bound
void adns_upload_firmware() {
  // send the firmware to the chip, cf p.18 of the datasheet
  Serial.println("Uploading firmware...");
  //Write 0 to Rest_En bit of Config2 register to disable Rest mode.
  adns_write_reg(Config2, 0x00);
  // write 0x1d in SROM_enable reg for initializing
  adns_write_reg(SROM_Enable, 0x1d);
  // wait for more than one frame period
  delay(10);  // assume that the frame rate is as low as 100fps... even if it should never be that low
  // write 0x18 to SROM_enable to start SROM download
  adns_write_reg(SROM_Enable, 0x18);
  // write the SROM file (=firmware data)
  adns_com_begin();
  SPI.transfer(SROM_Load_Burst | 0x80);  // write burst destination adress
  delayMicroseconds(15);
  // send all bytes of the firmware
  unsigned char c;
  for (int i = 0; i < firmware_length; i++) {
    c = (unsigned char)pgm_read_byte(firmware_data + i);
    SPI.transfer(c);
  //Read the SROM_ID register to verify the ID before any other register reads or writes.
  adns_read_reg(SROM_ID);
  //Write 0x00 (rest disable) to Config2 register for wired mouse or 0x20 for wireless mouse design.
  adns_com_end();
