I have had the same problem once with a LCD.. interesteringly there was a difference between doing high Ohm resistors and putting it to ground. while using 5kO i had a clear view but when i had more or less than that it began to get 'faded' again.
There is a strong likelihood then that you have an LCD designed to be used "outdoors" and subject to wide temperature variations. These LCD's actually use a small negative voltage on the contrast pin to compensate for extreme cold/heat.
An ICL7660 could be used to generate a negative source from the +3V source.
I'm still fairly new to electronic diagramming. From the scematic you've provided, you dont appear to be driving off anything but the arduino. Is that right?
Yes, the arduino supplies the voltages... very low current.
There are lots of options for LCD supply IC's. The 7660 is a generic voltage inverter chip and is one I had handy and used. If you need more contrast, you can swap the 3.3V input with the 5V and get -5V.
I've seen circuits that create negative voltage from the LM555 and some that even steal from the charge pump of the MAX232.
It's the simplest circuit I've come across without having a negative supply handy.
That's a handy sheet, looking through at their "simplest" circuit I've only got 100uF capacitors which is a pain.
My ceramics are all in the pF range.
I managed to dig up a few SMD caps but I'm not sure how effective they'd be (I'm not entirely sure the value is correct. I'd still be missing a 22uFcap)
I would not consider the values 100% critical... but the ratio could be important and all of the HANTRONICS advice is.
You are responsible for generating the PSEUDO Alternating Current source (0v-5v-0v transitions) with maybe the Arduino or a some external clock source like an LM555.
An electronics tinkerer should always have something handy to take apart to scrounge for parts... old PC power supplies... TV's, radios... etc. It is the very best in recycling behavior. All the parts may not work... but a big collection of junkbox parts can rescue you in time of need. (like when the stores are all closed)
Hey Willard, I picked up a ICL as you suggested. Do you think I would get away with using a 100uf cap rather than a 10? I know it's a huge difference, short of that I've only got <1uf caps.
With 100uf, I'm afraid that the 7660 might not oscillate. (frequency will be too low) The 1uF would be a better choice but will not be as efficient as 10uF. So, I'd try the 1uf and cross my fingers if it were up to me.
I'm not entirely sure whether I'm overloading the IC by using 100uf resistors - I assume it's just pulling up the voltage to 5v which is being brought down by the 10k pot.
Could you send the code of your PC2004A for the 4 lines shown in the pictures to joako@unizar.es? I have tried the 4 line display, but only lines 1 and 3rd are displayed.
From the datasheet for your device it appears that there is a negative voltage source available on pin 17, much like that provided with many GLCD devices.
If that is the case you can hook up a 10 K potentiometer with one end connected to pin 2 (+5v), the other end to pin 17 (-?v) and the wiper to pin 3. With the backlight also powered you should now be able to adjust the potentiometer until you see "blocks" on rows 1 and 3.
Next you should follow the tutorial at http://arduino.cc/en/Tutorial/LiquidCrystal - except leave the potentiometer connected as outlined above. Use the latest LiquidCrystal library, it is the most reliable library currently available.
With the 'Hello, world' program running you know that your LCD and software are working and you can proceed from there.
