hi, I recently got a MacBook Pro 13" and I downloaded Arduino IDE and connected my Arduino uno (I bought 5 months ago) to my computer (because my MacBook doesn't have a usb 3.0 port it has a usb c port instead so also got an adapter to connect my Arduino.)
my problem came when I tried to select a port in Arduino and it said no ports were discovered, I had my Arduino connected and everything the wires are new and there isn't any physical damage on my Uno. I have tried to google the solution but nothing has worked.
via system information on my MacBook I know it recognises my Uno as a device, I have updated the firmware, I have tried different wires, I have plugged it into my pc and it works. I have no clue what's wrong this has been an issue for 2 weeks now. please help...
Hi @ray_r1. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to run Arduino IDE from the command line, then share the output.
Please do this:
Open your Applications folder in Finder.
Open the Utilities folder.
Double-click on "Terminal".
Type the following command in the Terminal window:
Press ⌘+A.
This will select all the text in the Terminal window.
Press ⌘+C.
This will copy the selected text to the clipboard.
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
Press ⌘+V.
This will paste the output into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Last login: Fri Jan 6 11:07:18 on ttys000
ray@rays-macbook ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.0.3
Starting backend process. PID: 4873
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/ray/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-01-06T01:18:02.516Z root INFO Backend Object.initialize: 2.4 ms [Finished 0.471 s after backend start]
2023-01-06T01:18:02.517Z root INFO Backend Object.configure: 2.0 ms [Finished 0.471 s after backend start]
2023-01-06T01:18:02.517Z root INFO Backend MessagingContribution.onStart: 0.7 ms [Finished 0.471 s after backend start]
2023-01-06T01:18:02.517Z root INFO Backend OSBackendApplicationContribution.configure: 0.2 ms [Finished 0.492 s after backend start]
2023-01-06T01:18:02.517Z root INFO Backend DefaultWorkspaceServer.onStart: 0.1 ms [Finished 0.492 s after backend start]
2023-01-06T01:18:02.518Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 0.492 s after backend start]
2023-01-06T01:18:02.518Z root INFO Backend PluginLocalizationBackendContribution.initialize: 21.0 ms [Finished 0.492 s after backend start]
2023-01-06T01:18:02.518Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.1 ms [Finished 0.492 s after backend start]
2023-01-06T01:18:02.518Z root INFO Backend ElectronTokenBackendContribution.configure: 0.4 ms [Finished 0.493 s after backend start]
2023-01-06T01:18:02.519Z root INFO Backend PluginDeployerContribution.initialize: 0.2 ms [Finished 0.493 s after backend start]
2023-01-06T01:18:02.519Z root INFO Backend ConfigServiceImpl.onStart: 0.4 ms [Finished 0.493 s after backend start]
2023-01-06T01:18:02.519Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.2 ms [Finished 0.494 s after backend start]
2023-01-06T01:18:02.519Z root INFO Backend ArduinoDaemonImpl.onStart: 0.5 ms [Finished 0.494 s after backend start]
2023-01-06T01:18:02.519Z root INFO Backend NodeFileUploadService.configure: 0.8 ms [Finished 0.494 s after backend start]
2023-01-06T01:18:02.519Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/build/arduino-cli...
2023-01-06T01:18:02.519Z discovery-log INFO start
2023-01-06T01:18:02.520Z discovery-log INFO start new deferred
2023-01-06T01:18:02.520Z root INFO Backend HostedPluginLocalizationService.initialize: 0.2 ms [Finished 0.494 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend BoardDiscovery.onStart: 0.4 ms [Finished 0.495 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend FileDownloadEndpoint.configure: 0.3 ms [Finished 0.495 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend AuthenticationServiceImpl.onStart: 0.2 ms [Finished 0.495 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend PluginApiContribution.configure: 0.2 ms [Finished 0.495 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 0.495 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 0.496 s after backend start]
2023-01-06T01:18:02.520Z root INFO Backend PlotterBackendContribution.configure: 0.3 ms [Finished 0.496 s after backend start]
2023-01-06T01:18:02.521Z root INFO Theia app listening on http://localhost:51662.
2023-01-06T01:18:02.521Z root INFO Finished starting backend application: 1.9 ms [Finished 0.497 s after backend start]
2023-01-06T01:18:02.524Z root WARN The local plugin referenced by local-dir:/Users/ray/.arduinoIDE/plugins does not exist.
2023-01-06T01:18:02.524Z root WARN The local plugin referenced by local-dir:/Users/ray/.arduinoIDE/extensions does not exist.
2023-01-06T01:18:02.524Z root WARN The local plugin referenced by local-dir:/Users/ray/.arduinoProIDE/plugins does not exist.
2023-01-06T01:18:02.535Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-01-06T01:18:02.535Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-01-06T01:18:02.535Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2023-01-06T01:18:02.535Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-01-06T01:18:02.535Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-01-06T01:18:02.535Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-01-06T01:18:02.536Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-01-06T01:18:02.536Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-01-06T01:18:02.543Z root INFO Resolve plugins list: 23.5 ms [Finished 0.518 s after backend start]
2023-01-06T01:18:02.545Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js": 2.3 ms [Finished 0.521 s after backend start]
2023-01-06T01:18:02.546Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle": 1.5 ms [Finished 0.522 s after backend start]
2023-01-06T01:18:02.552Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-cpp/extension": 5.4 ms [Finished 0.528 s after backend start]
2023-01-06T01:18:02.553Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json/extension": 0.9 ms [Finished 0.529 s after backend start]
2023-01-06T01:18:02.553Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain": 0.2 ms [Finished 0.529 s after backend start]
2023-01-06T01:18:02.588Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-bg/extension": 35.4 ms [Finished 0.564 s after backend start]
2023-01-06T01:18:02.592Z daemon INFO INFO[0000] Using config file: /Users/ray/.arduinoIDE/arduino-cli.yaml
INFO[0000] arduino-cli version 0.29.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"51663"}
2023-01-06T01:18:02.593Z daemon INFO Daemon is running.
2023-01-06T01:18:02.629Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-cs/extension": 41.1 ms [Finished 0.605 s after backend start]
2023-01-06T01:18:02.681Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-de/extension": 51.6 ms [Finished 0.657 s after backend start]
2023-01-06T01:18:02.750Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-es/extension": 68.3 ms [Finished 0.725 s after backend start]
2023-01-06T01:18:02.750Z daemon INFO INFO[0000] Loading hardware from: /Users/ray/Library/Arduino15/packages
INFO[0000] Loading package arduino from: /Users/ray/Library/Arduino15/packages/arduino/hardware
INFO[0000] Checking signature error="opening signature file: open /Users/ray/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json.sig: no such file or directory" index=/Users/ray/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json signatureFile=/Users/ray/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json.sig
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: /Users/ray/Library/Arduino15/packages/arduino/tools
INFO[0000] Loading tools from dir: /Users/ray/Library/Arduino15/packages/arduino/tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: /Users/ray/Library/Arduino15/packages/builtin
INFO[0000] Checking existence of 'tools' path: /Users/ray/Library/Arduino15/packages/builtin/tools
INFO[0000] Loading tools from dir: /Users/ray/Library/Arduino15/packages/builtin/tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0000] Checking signature index=/Users/ray/Library/Arduino15/package_index.json signatureFile=/Users/ray/Library/Arduino15/package_index.json.sig trusted=true
INFO[0000] Adding libraries dir dir=/Users/ray/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
INFO[0000] Loading libraries index file index=/Users/ray/Library/Arduino15/library_index.json
2023-01-06T01:18:02.779Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-fr/extension": 30.0 ms [Finished 0.755 s after backend start]
2023-01-06T01:18:02.797Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-hu/extension": 17.4 ms [Finished 0.773 s after backend start]
2023-01-06T01:18:02.829Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-it/extension": 32.3 ms [Finished 0.805 s after backend start]
2023-01-06T01:18:02.830Z daemon INFO INFO[0000] Adding libraries dir dir=/Users/ray/Library/Arduino15/libraries location=ide
INFO[0000] Adding libraries dir dir=/Users/ray/Documents/Arduino/libraries location=user
2023-01-06T01:18:02.855Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ja/extension": 25.8 ms [Finished 0.831 s after backend start]
2023-01-06T01:18:02.857Z discovery-log INFO start request start watch
2023-01-06T01:18:02.857Z discovery-log INFO start requested start watch
2023-01-06T01:18:02.857Z discovery-log INFO start resolved watching
2023-01-06T01:18:02.891Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ko/extension": 36.0 ms [Finished 0.867 s after backend start]
2023-01-06T01:18:02.893Z daemon INFO INFO[0000] starting discovery builtin:mdns-discovery process
INFO[0000] starting discovery builtin:serial-discovery process
INFO[0000] started discovery builtin:mdns-discovery process
INFO[0000] started discovery builtin:serial-discovery process
INFO[0000] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:serial-discovery
INFO[0000] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:mdns-discovery
2023-01-06T01:18:02.908Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-nl/extension": 17.2 ms [Finished 0.884 s after backend start]
2023-01-06T01:18:02.934Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-pl/extension": 26.0 ms [Finished 0.910 s after backend start]
2023-01-06T01:18:02.962Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-pt-BR/extension": 27.6 ms [Finished 0.938 s after backend start]
2023-01-06T01:18:02.992Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ru/extension": 29.9 ms [Finished 0.968 s after backend start]
2023-01-06T01:18:03.019Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-tr/extension": 27.0 ms [Finished 0.995 s after backend start]
2023-01-06T01:18:03.038Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-uk/extension": 18.5 ms [Finished 1.013 s after backend start]
2023-01-06T01:18:03.067Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-zh-hans/extension": 26.8 ms [Finished 1.040 s after backend start]
2023-01-06T01:18:03.067Z root INFO Deploy plugins list: 23.5 ms [Finished 1.043 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-01-06T01:18:03.423Z daemon INFO INFO[0000] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0000] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0000] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-01-06T01:18:03.436Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 170.6 ms [Finished 0.854 s after frontend start]
2023-01-06T01:18:03.495Z daemon INFO INFO[0000] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0000] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0000] from discovery builtin:serial-discovery received message type: start_sync, message: OK
INFO[0000] from discovery builtin:serial-discovery received message type: add, port: /dev/cu.Bluetooth-Incoming-Port
2023-01-06T01:18:03.496Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
2023-01-06T01:18:03.564Z root INFO Start frontend contributions: 336.1 ms [Finished 0.980 s after frontend start]
2023-01-06T01:18:03.564Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-01-06T01:18:03.580Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4] Waiting for backend deployment: 27.2 ms [Finished 1.006 s after frontend start]
2023-01-06T01:18:03.631Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-01-06T01:18:03.631Z root INFO >>> Restoring the layout state...
2023-01-06T01:18:03.631Z root INFO <<< Nothing to restore.
2023-01-06T01:18:03.631Z root INFO Initialize the workbench layout: 13.1 ms [Finished 1.027 s after frontend start]
2023-01-06T01:18:03.631Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-01-06T01:18:03.775Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884) starting instance
2023-01-06T01:18:03.978Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4] Sync of 21 plugins: 385.8 ms [Finished 1.392 s after frontend start]
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][marus25.cortex-debug]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][arduino.vscode-arduino-tools]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][vscode.cpp]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][vscode.json]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][vscode.json-language-features]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-01-06T01:18:03.979Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-01-06T01:18:03.980Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4] Load contributions of 21 plugins: 13.6 ms [Finished 1.405 s after frontend start]
2023-01-06T01:18:03.990Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-01-06T01:18:03.990Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-01-06 11:18:04.050 Arduino IDE Helper (Renderer)[4879:356178] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2023-01-06 11:18:04.050 Arduino IDE Helper (Renderer)[4879:356178] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2023-01-06T01:18:04.253Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): PluginManagerExtImpl/init()
2023-01-06T01:18:04.255Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.257Z root INFO [hosted-plugin: 4884] Debugger contribution has been registered: cortex-debug
2023-01-06T01:18:04.257Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-arduino-tools@0.0.2-beta.5 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.258Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.258Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.258Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.259Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.259Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-cs@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.260Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-de@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.260Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-es@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.261Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-fr@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.261Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.262Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-it@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.262Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-ja@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.263Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-ko@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.263Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.263Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-pl@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.264Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-pt-BR@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.265Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-ru@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.266Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-tr@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.266Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.266Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): initializing(vscode-language-pack-zh-hans@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
2023-01-06T01:18:04.292Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][marus25.cortex-debug]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][arduino.vscode-arduino-tools]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][vscode.cpp]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][vscode.json]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][vscode.json-language-features]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-01-06T01:18:04.310Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-01-06T01:18:04.311Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-01-06T01:18:04.319Z root INFO [hosted-plugin: 4884] PLUGIN_HOST(4884): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2023-01-06T01:18:04.334Z root INFO [hosted-plugin: 4884] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-01-06T01:18:04.335Z root INFO [hosted-plugin: 4884] GDB server console created
2023-01-06T01:18:04.340Z root INFO [7c47985a-5eb8-499b-bf7b-848060ed5ce4] Start of 21 plugins: 356.1 ms [Finished 1.768 s after frontend start]
2023-01-06T01:18:04.574Z root INFO Frontend application start: 1149.7 ms [Finished 2.550 s after backend start]
2023-01-06T01:18:04.576Z root INFO Replace loading indicator with ready workbench UI (animation): 816.1 ms [Finished 1.846 s after frontend start]
2023-01-06T01:18:04.579Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-01-06T01:18:04.579Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
Checking for update
2023-01-06T01:18:05.141Z root ERROR ---- !!!SLOW!!! DURATION: search took 499.846 ms. Args: [{"type":"Updatable"}] ----
Update for version 2.0.3 is not available (latest version: 2.0.3, downgrade is allowed).
here you go im not entirely sure if all of it loaded.
I also bought another usb c to usb adapter and its still not working.
From this I can see that the serial-discovery tool Arduino IDE uses to get the list of serial ports available on your computer was able to see the built-in system /dev/cu.Bluetooth-Incoming-Port port (that port is only shown in Arduino IDE after you check the "Show all ports" checkbox since it is known that it isn't an Arduino board), but it is not finding any other serial ports.
You say that "system information" shows your board, which indicates that macOS does recognize it, but now we see that Arduino IDE is never being told about the existence of a port for the Uno. So the question is: where exactly along the chain of software between macOS and Arduino IDE is the problem?
I think the next step in troubleshooting the p check whether the low level serial-discovery tool used by the Arduino development software to find ports is behaving and able to see the port of your board.
I'll provide the instructions here:
NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
During all this, keep an eye out for anything that doesn't match the expected behavior as described at each step.
Open your Applications folder.
Open Utilities.
Run this command:
ls ~/Library/Arduino15/packages/builtin/tools/mdns-discovery
You will now see a list of the versions of serial-discovery which are installed on your computer. Take note of the highest version on the list (recent versions of Arduino IDE 2.x always use the newest one)
For example, if you see output like this:
(where <newest version> is the version number you found at step 3) serial-discovery will now start. There won't be any obvious sign of this other than that there is no longer a command prompt at the cursor in the terminal.
Type the following command:
HELLO 1 "arduino-cli 0.20.2"
Press the Enter key.
You should now see a response printed exactly like this:
