Port not recognized
For any useful feedback we need:
  1. Schematic
  2. Better explanation of the issue. "Everything works fine...." However you also worded it to suggest the ultrasonic sensor was not connected.
Some pictures of your project would help, so we can see your component layout.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
I have merged your cross-posts @phantom_20.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Thanks guys for the help. It started working
It would be useful if you posted what was actually wrong and how it was solved. Some might try a similar project and run into the same issue.
Ok then, well, my breadboard has 30 terminals so in my attempt where it was not working I put it the ultrasonic sensor pins at a1,b1, c1 and d1. However this had not worked so I put it the other way around near the 15 mark area and when I connected the gnd to the negative terminal of the breadboard my project started working fine. Not sure what was the issue.
15 mark area meaning it was perpendicular to the other one
In a numbered column, all pins are connected as shown below. So yes, Vcc and GND in the same numbered column will cause a short.
                    1 1 1
  1 2 3 4 5 6 7 8 9 0 1 2
A o o o o o o o o o o o o
B o o o o o o o o o o o o
C o o o o o o o o o o o o
D o o o o o o o o o o o o
E o o o o o o o o o o o o
Note that A..E are independent of F..J.
HI,
Can you please post some images of your project in the breadboard?
See post #24.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Ohk thx for clearing that
Yeah I'll send it a bit later
Apologies for the late reply
When I put it like this the problem was fixed but if you put it perpendicular that's when it gets short.
