Hello everyone,
I’m working on an IoT project and I’m facing a stability issue with the cellular connection when switching a fan load.
Hardware Setup
Board: Arduino Portenta C33
Carrier: Portenta Mid Carrier
Cellular Modem: Arduino Pro 4G Module (Global)
Actuator: Two 5V , 0.3 A DC fans
Switch: DC MOSFET switch module
Power supply:5V 2A battery
The fan is controlled using Arduino IoT Cloud .
Problem Description:
When I turn the fan ON from the cloud dashboard , the following happens:
- The fan turns ON correctly
- After turning the fan on for few seconds ,the 4G connection disconnects
- After a few seconds the 4G reconnects automatically
If I connect the USB cable to the computer along with the battery , everything works perfectly:
- 4G connection remains stable
- Fan turns ON and OFF normally
- No disconnection occurs
But if the system runs only from the 5V 2A battery , the behavior is:
- Device connects to 4G normally
- When the fan is turned ON , fan runs for a few seconds
- Then the 4G connection goes offline
- After some time it reconnects again
Fan Switching Circuit
I replaced a relay with a MOSFET switch module .
MOSFET connections
| MOSFET Pin | Connection |
| IN | PWM 5 On Portenta mid carrier |
| GND | GND |
| LOAD + | Both the fans red wire(+) |
| LOAD− | Both the fans black wire (-) |
| Power + | 5V Supply |
Power- GND
I have also added 1000uF capacitor across the load, but the issue is not rectified. I would like if anyone would tell what is the issue and how to rectify it to get the required output
Thank You
