I'm trying to port some Arduino code to a microcontroller in c.
byte ZERO = 0x00;
boolean EndFlag=0;
Are the byte and boolean keywords in Arduino supported in c?
Many thanks
C
byte ZERO = 0x00;
boolean EndFlag=0;
Many thanks
C
It depends on which version of C your micro compiler supports.
Here's a wikipedia entry on the C data types.
If you need them, just define the missing datatypes in a header file:
typedef unsigned char byte;
boolean is a little trickier, but for your purposes, maybe this is OK:
typedef unsigned char boolean;
You can probably/possibly use "bool" instead of "boolean".
Which compiler/micro?
Edit:
The header stdbool.h in the C Standard Library for the C programming language contains four macros for a Boolean data type. This header was introduced in C99.
The macros as defined in the ISO C standard are :
bool which expands to _Bool
true which expands to 1
false which expands to 0
__bool_true_false_are_defined which expands to 1
Sorry arduinodlb, I just realised that you pointed out exactly the same thing in your last post.
