What is a boolean ?
Happy New Year Everybody!
I have a stupid question, i know what's all that stuff but i can't understand the reason...
Why the boolean type is a int 8 bit ?
True, False, Null (may be)
That's make one or (may be two) bit(s).
Why that's in arduino core ?
There's no data type that can store one bit, so bool is based on an 8-bit integer, being the smallest allocatable unit in most architectures.
Happy New Year as well! :slight_smile:
From the file \Arduino\hardware\arduino\cores\arduino\Arduino.h
typedef uint8_t boolean;
It's just an 8-bit unsigned integer value.
Jiggy-Ninja:
Here's a little sketch to show you the difference between a bool and a boolean.
bool b;
boolean bn;
  for (int i = -2; i < 3; i += 2) {
    b = i;
    bn = i;
    Serial.print(b);
    if (b) {
      Serial.println("  b is true");
    else {
      Serial.println("  b is false");
    Serial.print(bn);
    if (bn) {
      Serial.println("  bn is true");
    else {
      Serial.println("  bn is false");
A boolean is just a number with a specific human concept attached to it:
0 = false
1+ = true
So 4 is true, 83 is true, 254 is true, but 0 is false.
As already stated the Arduino cannot store a single value of less than 8 bits, so all 8 bits are used and effectively 7 are wasted.
You can compress up to 8 booleans into a single 8 bit struct if you need to save space:
struct myFlags {
  unsigned flag1:1;
  unsigned flag2:1;
  unsigned flag3:1;
  unsigned flag4:1;
  unsigned flag5:1;
  unsigned flag6:1;
  unsigned flag7:1;
  unsigned flag8:1;
} __attribute__((packed)) flags;
flags.flag3 = 1;
flags.flag2 = 0;
