I bought this recently. I'm trying to use it and I am following this guide.
Mine seems to be a little bit different than the one they are showing. Is it possible to follow this guide? I've looked at this github repo, but I don't really understand it.
When I run the code from the adafruit guide I get: Could not find a valid BME680 sensor, check wiring!
I have not changed the code at all (because I don't know if I need to). I imported the example code from File->Examples->Adafruit_BME680->bmp680test. I also followed I2C Wiring.
Could someone point me in the right direction? Thank you!
The first thing that I do when I have trouble with an I2C device is to run an I2C scanner to confirm the device address and that the device is on the I2C bus. If not success, double check your wiring and confirm that the required pullup resistors are on the SDA and SCL lines. Some modules have the pullups and some do not.
// I2C scanner by Nick Gammon. Thanks Nick.
#include <Wire.h>
Serial.begin (115200); //***** make sure serial monitor baud matches *****
// Leonardo: wait for serial port to connect
while (!Serial)
Serial.println ();
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
Wire.begin();
for (byte i = 1; i < 120; i++)
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
} // end of setup
void loop() {}
groundFungus:
#include <Wire.h>
while (!Serial)
I think I got repo (that I mention in the first post) to work (in the sense that I can run it). But it seems that it returns a similar message . Which seems related to ID and the above address (0x76)?
The default address for the sensor is 0x77 in the Adafruit library. You can change the default to 0x76 in the begin() statement that should be in setup(). Try setting the address in the Adafruit BME680 example like so:
if (!bme.begin(0x76)) { // ********** change from the default address (0x77) to 0x76
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
groundFungus:
while (1);
