POST to HTTPS from Arduino MKR1000
Hi, I'm trying to input data from a Arduino MKR1000 into a database. I have a PHP script on a server to do this which is working when I use the command from mac terminal: curl -d "depth=300" https://people.bath.ac.uk/XXX/XXX/test.php
My PHP script is:
<?php
if ($_SERVER["REQUEST_METHOD"] == "POST") {
    // Get the post data
    $reading = $_POST["depth"];
    $bottleId = 12;
    // Connect to MySQL
    require_once("./connect_to_mysql.php");
    // Insert into raw data table
    $sql = "INSERT INTO tbl_raw
        bottleId,
        reading
    VALUES
        $bottleId,
        $reading
    if ($mysqli->query($sql) === TRUE) {
        echo "New record created successfully";
        echo "Error: " . $sql . "
" . $mysqli->error;
    $mysqli->close();
I am trying to now POST to this script using Arduino IDE. For now I am not doing any sensor readings, just sending a value for "depth". My code isn't working and after searching online I can't figure out why. Any help is hugely appreciated!
#include <WiFi101.h>
char ssid[] =      "XXXXX";                  // network to join
char pass[] =      "XXXXX";                  // password for wifi network
int status = WL_IDLE_STATUS;
char server[] = "people.bath.ac.uk";       // server URL
String postData;
String postVariable = "depth=";
WiFiClient client;
  // Start serial connection for feedback
  // Connect to WiFi
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(10000);                         // wait 10 sec for connection
  // Log WiFi details
  Serial.print("Connected to: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  IPAddress gateway = WiFi.gatewayIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // Readings
  int depth = 500;
  int bottleId = 11;
  postData = postVariable + depth;
  // Connect to php script at port 80
  if (client.connect(server, 80)) {
    Serial.println("Connected to server.");
    client.println("POST /XXX/XXX/test.php HTTP/1.1");
    client.println("Host: people.bath.ac.uk");
    client.println("Content-Type: application/x-www-form-urlencoded;");
    client.print("Content-Length: ");
    client.println(postData.length());
    client.println();
    client.print(postData);
    Serial.println("Failed to connect to server.");
  if (client.connected()) {
    client.stop();
  Serial.println(postData);
  delay(3000);
Look at File | Examples | WiFi101 | WiFiSSLClient assuming you installed the WiFi101 library.
Also add the SSL/TLS domain using the firmware updater.
