Hi, I'm trying to input data from a Arduino MKR1000 into a database. I have a PHP script on a server to do this which is working when I use the command from mac terminal: curl -d "depth=300" https://people.bath.ac.uk/XXX/XXX/test.php
My PHP script is:
<?php
if ($_SERVER["REQUEST_METHOD"] == "POST") {
// Get the post data
$reading = $_POST["depth"];
$bottleId = 12;
// Connect to MySQL
require_once("./connect_to_mysql.php");
// Insert into raw data table
$sql = "INSERT INTO tbl_raw
bottleId,
reading
VALUES
$bottleId,
$reading
if ($mysqli->query($sql) === TRUE) {
echo "New record created successfully";
echo "Error: " . $sql . "
" . $mysqli->error;
$mysqli->close();
I am trying to now POST to this script using Arduino IDE. For now I am not doing any sensor readings, just sending a value for "depth". My code isn't working and after searching online I can't figure out why. Any help is hugely appreciated!
#include <WiFi101.h>
char ssid[] = "XXXXX"; // network to join
char pass[] = "XXXXX"; // password for wifi network
int status = WL_IDLE_STATUS;
char server[] = "people.bath.ac.uk"; // server URL
String postData;
String postVariable = "depth=";
WiFiClient client;
// Start serial connection for feedback
// Connect to WiFi
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
delay(10000); // wait 10 sec for connection
// Log WiFi details
Serial.print("Connected to: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
IPAddress gateway = WiFi.gatewayIP();
Serial.print("IP Address: ");
Serial.println(ip);
// Readings
int depth = 500;
int bottleId = 11;
postData = postVariable + depth;
// Connect to php script at port 80
if (client.connect(server, 80)) {
Serial.println("Connected to server.");
client.println("POST /XXX/XXX/test.php HTTP/1.1");
client.println("Host: people.bath.ac.uk");
client.println("Content-Type: application/x-www-form-urlencoded;");
client.print("Content-Length: ");
client.println(postData.length());
client.println();
client.print(postData);
Serial.println("Failed to connect to server.");
if (client.connected()) {
client.stop();
Serial.println(postData);
delay(3000);
