pot to controll on and off multiple led. between value?
hello, very new to programming and arduino.
i got the below scetch working fine, but what if i want to turn led1 on between 100-200
and led2 200 - 250? i need a "inbetween" value
and what about value being exactly 200 or 201?
const int sensorPin = A0;    // pin that the sensor is attached to
const int ledPin = 9;        // pin that the LED is attached to
const int ledPin1 = 10;
// variables:
int sensorValue = 0;         // the sensor value
int sensorMin = 1023;        // minimum sensor value
int sensorMax = 0;           // maximum sensor value
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin1, OUTPUT);
  sensorValue = analogRead(sensorPin);
  sensorValue = map(sensorValue, sensorMin, sensorMax, 0, 255);
  sensorValue = constrain(sensorValue, 0, 255);
if(sensorValue < 200)// what can i write here? i need a between value? how do i do that?
    digitalWrite(ledPin, HIGH); // turn on LED
    digitalWrite(ledPin, LOW);  // turn off LED
if(sensorValue > 200)
    digitalWrite(ledPin1, HIGH); // turn on LED
    digitalWrite(ledPin1, LOW);  // turn off LED
if ((x > minValue) and (x < maxValue))
( How is this COVID-related?)
thank you so much =) so praud of myself for getting this tiny (may not be the best code) working.
one small victory for me, thank you =)
tbh it don*t have much to do with covid-19 but i could not figure out wich sub forum was the correct place.
(and yes ive read the newbie stickies)
const int ledPin2 = 11;
const int ledPin3 = 12;
// variables:
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
if ((50 < sensorValue) and (100 > sensorValue))
if ((100 < sensorValue) and (150 > sensorValue))
if ((150 < sensorValue) and (200 > sensorValue))
    digitalWrite(ledPin2, HIGH); // turn on LED
    digitalWrite(ledPin2, LOW);  // turn off LED
if (200 < sensorValue)
    digitalWrite(ledPin3, HIGH); // turn on LED
    digitalWrite(ledPin3, LOW);  // turn off LED
  Serial.println(sensorValue);
@mikki1211
You should know better by now !
Your topic was Moved to it's current location / section as it is more suitable.
Could you take a few moments to Learn and Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Here is a way to include the values that are exactly 100, 150, and 200. Also you had a lot of extra braces creating unnecessary code blocks.
// variables:
  if ((50 < sensorValue) and (100 >= sensorValue))
  if ((100 < sensorValue) and (150 >= sensorValue))
  if ((150 < sensorValue) and (200 >= sensorValue))
