HELLO EVERYBODY IN THIS PART OF THE PROGRAM I TURN THE POTENTIOMETER AND THE SEGMENT ON THE DISPLAY CHANGES FOR DIFFERENT VALUES OF IT......I HAVE TWO VERSIONS OF THE SAME PROGRAM, BUT THE LAST ONE DOESNT'T WORK....SOMEONE CAN KINDLY SEE WHAT I CAN CHANGE IN THE FIRST??
FIRST VERSION THAT WORKS BUT IT IS NOT VERY ELEGANT
#define LATCH 7
#define CLOCK 8
#define DATA 4
#define POT2 1
#define buttonPin 11
#define BUZZER 3
#define pitch 1000
#include "pitches.h"
int prec_Stato=0;
unsigned long elapsed;
int fractional;
unsigned long start;
unsigned long finished;
int melody[] = {
NOTE_C4, NOTE_G3,NOTE_G3, NOTE_A3, NOTE_G3,0, NOTE_B3, NOTE_C4};
int noteDurations[] = {
4, 8, 8, 4,4,4,4,4 };
int buttonPushCounter;
const byte numeral[10] = {
//ABCDEFG /dp
B11000000, // 0//okokok
B11111001, // 1//okokok
B10100100, // 2//okokok
B10110000, // 3//okokok
B10011001, // 4//okokok
B10010010, // 5//okokok
B10000010, // 6//okokok
B11111000, // 7//okokok
B10000000, // 8//okokok
B10011000, // 9//okokok
int buttonState;
void displayResult()
float h, m, s, ms;
unsigned long over;
elapsed = finished - start;
h= int (elapsed/3600000);
over=elapsed%3600000;
m= int (over/60000);
over=over%60000;
s=int(over/1000);
ms=over%1000;
Serial.print("Raw elapsed time: ");
Serial.println(elapsed);
Serial.print("Elapsed time: ");
Serial.print(h,0);
Serial.print("h ");
Serial.print(m,0);
Serial.print("m ");
Serial.print(s,0);
Serial.print("s ");
Serial.print(ms,0);
Serial.print("ms ");
void displayDigit()
int y = analogRead(POT2);
if (y>0 && y<100)
digitalWrite(LATCH,LOW);
shiftOut(DATA,CLOCK,MSBFIRST,numeral[1]);
digitalWrite(LATCH,HIGH);
start = millis();
else if (y>100 && y<200)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[2]);
start = millis();
else if (y>200 && y<300)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[3]);
start = millis();
else if (y>300 && y<400)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[4]);
start = millis();
else if (y>400 && y<500)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[5]);
start = millis();
else if (y>500 && y<600)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[6]);
start = millis();
else if (y>600 && y<700)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[7]);
start = millis();
else if (y>700 && y<800)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[8]);
start = millis();
else if (y>800 && y<1000)
shiftOut(DATA,CLOCK,MSBFIRST,numeral[9]);
start = millis();
pinMode(LATCH, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(DATA,OUTPUT);
pinMode(POT2, INPUT);
pinMode(buttonPin, INPUT);
//digitalWrite(buttonPin, HIGH);
digitalWrite(buttonPin, LOW);
pinMode(BUZZER,OUTPUT);
displayDigit();
int buttonState = digitalRead(buttonPin);
if (buttonState!=prec_Stato)
if (!buttonState)
tone(BUZZER,pitch);
Serial.print("pressed");
finished = millis();
delay(2000);
displayResult();
delay(2000);
Serial.print("NOT pressed");
noTone(3);
prec_Stato=buttonState;
SECOND VERSION THAT DOESN' T WORK
#define LATCH 7
#define CLOCK 8
#define DATA 4
#define POT2 1
#define BUZZER 3
#define pitch 1000
int prec_Stato=0;
int i=0;
int j=0;
int fractional;
char range[10];
//ABCDEFG /dp
int buttonState;
float h, m, s, ms;
unsigned long over;
over=over%60000;
s=int(over/1000);
ms=over%1000;
Serial.print(h,0);
Serial.print("h ");
Serial.print(m,0);
Serial.print("m ");
Serial.print(s,0);
Serial.print("s ");
Serial.print(ms,0);
void displayDigit()
range[10]=1023/10;
for (j=0;j<10; j++)
for(i=0;i<10;i++)
while (y==range*)*
digitalWrite(LATCH,LOW);*
shiftOut(DATA,CLOCK,MSBFIRST,numeral[j]);
start = millis();
Serial.begin(9600);*
*//digitalWrite(buttonPin, HIGH); *
displayDigit(); -
int buttonState = digitalRead(buttonPin);*
if (buttonState!=prec_Stato)*
if (!buttonState)*
tone(BUZZER,pitch);*
Serial.print("pressed");*
finished = millis();*
delay(2000);*
displayResult();*
delay(2000);*
else*
Serial.print("NOT pressed");*
noTone(3);*
prec_Stato=buttonState;*
//start = millis();
/* while (digitalRead(buttonPin)==LOW)
//wait until I press the button*
/* if(digitalRead(buttonPin)==LOW)
- tone(BUZZER,pitch);*
- Serial.print("pressed");*
_ } */_
// finished = millis();
//noTone(3);
MANY THANKS
