Hi, I’m trying to get the potentiometer seen at the top left of the photo to work, essentially as a dimmer. I’ve managed to upload the Arduino sketch, but it isn’t working. Any help would be greatly appreciated!
NB: I have little-to-no electronics experience so my understanding of jargon is limited.
`/* SENSOR_LIGHTS: Potentiometer >> LED (Single Channel Script)
This example dims light levels using an LED on pin 11 and a potentiometer on A0.
Created by Ryan Achten | SOMA | somavisions.com
This example code is in the public domain. */
int potentLevel; int ledLevel;
//*************************CHECK*****************************
int led = 11; // the pin that the LED is attached to int inputPin = A0; // the pin that the potentiometer is attached to
//*************************CALIBRATE*************************
const int numReadings = 1; //change this to alter the number of values to be averaged int potentMin = 280; int potentMax = 700; //maximum output from potentiometer int loopDelay = 100; //delay time between loops. Too low may cause overclocking
// while too high may cause delayed sensor response
int potentAve = 0; int readings[numReadings]; int index = 0; int total = 0;
// the setup routine runs once when you press reset: void setup() {
//*************************POTENT >> LED SETUP CODE*************************
pinMode(led, OUTPUT);
//***************************SMOOTH SETUP CODE***************************** // initialise all the readings to 0: for (int thisReading = 0; thisReading < numReadings; thisReading++) readings[thisReading] = 0;
//****************************SMOOTH LOOP CODE****************************
total= total - readings[index];
readings[index] = analogRead(inputPin); total= total + readings[index];
index = index + 1;
if (index >= numReadings)
index = 0;
potentAve = total / numReadings;
Serial.print("Average Potentiometer Readings: "); Serial.println(potentAve);
//*************************POTENT >> LED LOOP CODE*************************
ledLevel = map(potentAve, potentMin, potentMax, 0, 255); Serial.print("LED Level: "); Serial.println(ledLevel, DEC); analogWrite(led, ledLevel);
Serial.println(); delay(loopDelay);
+1 about the base resistor.
void setup was also commented out
This might work.
I just corrected the many mistakes I saw. Might have missed one…
int potentLevel;
int ledLevel;
int potentAve = 0;
int index = 0;
int total = 0;
total = total - readings[index];
readings[index] = analogRead(inputPin); total = total + readings[index];
index = index + 1;
index = 0;
delay(loopDelay);
Needs a GATE resistor, sorry, my / fritzy misread.
I was halfway into fetal position when I noticed it.
Goes to show what a half decent schematic would do, I should give up trying to read fritzy when I'm tired.
