I'm doing a project involving an Arduino and a 32x32 LED matrix. I'd like to power this using one DC power adapter. For the LED matrix they recommend a 5V 2A DC adapter.
Is the Arduino able to output 5V 2A if I for example get a 12V 3A DC adapter to power the Arduino? Or do you recommend me solving this differently?
Definitely not. Your Arduino will be toast.
You can probably power your Arduino from the led 5 volt supply bypassing the regulator. What Arduino are you using? You may need an additional electrolytic & ceramic capacitor to filter the supply if the led circuits generate too much noise. Two seperate supplies will obviously solve the problem but this is often not necessary.
Notice that your Arduino boards have connections labelled 5V+. If you leave the main power connector unused, any 5v supply on this pin powers the board. I do this all the time. I'm sure the Mega is similar. Be careful that it is 5v and only 5v. No protection against reversing leads.
Someone with Mega experience will hopefully comment.
[quote author=joe mcd link=topic=186921.msg1384031#msg1384031 date=1378674996]
Someone with Mega experience will hopefully comment.[/quote]
Okay, to be absolutely clear; I'm looking at my Uno, it is the connection 5V (that usually outputs 5V, the one between 3.3V and GND) you are talking about? In that case I don't see any problem with your first suggestion joe mcd (Taking 5V from adapter powering the leds, through a capacitor). I'd still like to hear anyone with Mega experience regarding this.
@GaryF why don't you simply use pull ups for the LED matrix and operate it using a low output levels from the Arduino. First of all, you should've chosen an LED matrix that inherently works on low voltage levels, by that I mean you select a row by given a 0V signal on an output pin of Arduino and rest of the time the LED is automatically pulled up. So basically the arduino acts as a sink. You can use current limiting resistors to ensure that your controller doesn't have to sink more current than specified in its datasheet. Now even if you have an LED matrix which operates on high voltage level, you can simply pull up the pins and use NOT-gate ICs with that to convert the signal to show a high. This might use a little more power but it's better than blowing up your controller. Do tell us what solution you used and what the current ratings were.
