Hi
My issues is similar to this post seen here.
https://forum.arduino.cc/index.php?topic=496308.0
I have been told to start my own thread, so here i go.
The code words great and all is working as expected, but on power up the ( ESP8266 wifi module ) the GPIO2 output goes high for about two seconds before turning off.
I would prefer this, not to happen
I am not even sure if it is possible to add some extra code lines to stop this from happening on power up.
Sorry but i am not a coder.
although i have read the other post i have tried adding some extra code lines but i was not successful.
Any suggestion i would greatly appreciate your help.
Thank in advance
here is my sketch.
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
const char* ssid = "mywifi";
const char* password = "mywifipassword";
const char* host = "192.168.1.10"; // Your domain
String path = "/wifiarduino/light.json";
const int pin = 2;
pinMode(pin, OUTPUT);
pinMode(pin, HIGH);
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
int wifi_ctr = 0;
Serial.print(".");
Serial.println("WiFi connected");
Serial.println("IP address: " + WiFi.localIP());
Serial.print("connecting to ");
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
client.print(String("GET ") + path + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: keep-alive\r\n\r\n");
delay(500); // wait for server to respond
// read response
String section="header";
while(client.available()){
String line = client.readStringUntil('\r');
// Serial.print(line); // we’ll parse the HTML body here
if (section=="header") { // headers..
Serial.print(".");
if (line=="\n") { // skips the empty space at the beginning
section="json";
else if (section=="json") { // print the good stuff
section="ignore";
String result = line.substring(1); // Parse JSON
int size = result.length() + 1;
char json[size];
result.toCharArray(json, size);
StaticJsonBuffer<200> jsonBuffer;
JsonObject& json_parsed = jsonBuffer.parseObject(json);
if (!json_parsed.success())
Serial.println("parseObject() failed");
return;
// Make the decision to turn off or on the LED
if (strcmp(json_parsed["light"], "on") == 0) {
digitalWrite(pin, HIGH);
Serial.println("LED ON");
else {
digitalWrite(pin, LOW);
Serial.println("led off");
Serial.print("closing connection. ");
