I am working on a project called Power line communication for smart meter networks.I am developing a power line modem myself but in some troubles.So i thought of using a modem called KQ-130f which is manufactured by some Chinese company.I know it works with arduino,But program is not available in internet directly.I used basic serial communication programming,but didnt work for that module.I contacted some youtubers,but they are asking lot of money,which i dont have since i spent a lot on designing one.
Anyway thats why i came to you.If some of u could help me with the program i will be much grateful.
I am attaching KQ130 datasheet ,and a program to transmit data bw kq330f by arduinojson.h header file.eventhough i have tx file program u dont have its rx file.So check everything and help me .
How can i be more specific,i want to transmit a string from one arduino to another arduino using a kq13f module.
Arduino------>kq130f--------->powerline------>kq130f------->arduino
like this.
And i used general serial programing code,it doesnt work,they suggested UART or MOBUS protocols ,but i dont know how to setup a protocol.
I tried serial.println() and read functions since Kq130f has rx and tx pins,but it didnt work.Then i googled and stuff and found that people didnt use direct serial communication with the module.Thats when i found the ino file up there to transmit data,but he didnt upload the recieve data file.So i dont know how to communicate with kq130f.
i dont want u to write code for me.I dont understand arduinojson.h programing logic.So if someone could shed some light into what i should do to read data,thats what i am looking for
Well here you go then ArduinoJson Documentation. Take a look at the serialization/deserialization sections. However, the json library has nothing to do with you wanting to use the plc module.
The thing is the data sheet doesnot specify anything about how to make work with arduino.They only documented how to connect with some unknown microcontroller.I have seen this device used with arduino.But as i said code is not available anywhere in the internet.
i need whatever help i can get. i will share my entire project if someone can help me.This powerline modem part is the only thing that keeping me from finishing my project
ThottiKuttapan:
Take a closer look at the datasheet. You can use transparent mode or custom operating mode. I'd suggest the custom mode. In your code, build your packet, determine the number of bytes to send and output that to the modules RX pin. After sending the data length you can output your data one byte after the other. The module should send that over the powerline. The datasheet has some example C codes at the very end ...
Once more, the json doesn't have anything to do with the powerline communication. I'd best if you get it to work with basic datatypes. Then you can serialize/deserialize this to/from json later.
I am doing a smart meter project using power line communication.For that i use kq-130f module as plcc module.It has tx and rx pin to which we send serial data and recieve it at other end.But when i send my data through basic serial.println() function it didnt work.When i looked into data sheet,they prefer using UART,MOBUS protocols,which i dont have any idea about.
Arduio mega-------->kq130f--------------->powerline--------->kq130f------->arduino uno
i want to sent serial data(sensor values) from mega to uno like this.
I am attaching datasheet along my topic.I want to know how to make this module work.There is somekind of program for another microcontroller at the end of datasheet which i have no idea about.So help is appreciated.
