Hi, i am trying to make a rc car/auto but i found a problem.
I use 2 dc motors: 1 for the back wheels, one for the steering, when i try to turn while the rear motor is going/active i have a huge loss of power, seems like the power is splitted between the two motors.
I use a h-bridge and i connected a 9v battery to power both motors.
My question is: is this a voltage battery problem, so i need a more powerful one? Or is it a code problem?
In the attachements you have my code and the sketch i followed to make the circuit (the only difference is that i have 2 motors)
9V batteries are good for 10mA, OK with 25mA, anything more and you overload them. Motors are typically in the amps range, not milliamps. R/C cars often have powerful motors capable of 10's of amps stall current -
LiPo batteries can provide this, perhaps 3 to 4 orders of magniture more current available than from a PP3
sized 9V battery...
I just need another help, looking for batteries i found a lot of models with different voltage, amperage etc etc and i really don't know how to chose.
Searching in an online shop i fuond two models of the same producer with almost the same price, the first is 3 cells 11,1v ; 1000mAh ; 45C , the second 2 cells 7,4v ; 1350mAh ; 45C.
