Hi guys,
I'd like to control a 1m WS2812b led strip (with 60 leds) for my PC case using an Arduino Nano (ATmega 328P). Now, I didn't understand exactly how to properly power all those LEDs using a normal 5V pin and a digital pin, can you help me?
Thanks
What is a "normal 5v pin"?
I assume you'll power Arduino and LEDs from the computer's psu?
exactly
5v from psu to LEDs, and 5v from psu to Nano. Grounds connected. Data to Nano.
What's the confusion?
60 LEDs at 60mA each is 3.6 Amps.
So your power supply needs to be able to supply that on top of what it is already supplying.
He'll be fine. Even if LED strips drew that full figure, it'd be a 20 watt load tops which even the scrimpiest Dell can spare.
Directly from the PSU, yes. But I hope TS doesn't try to do this via USB
