I am planning on powering a MKR1000 with an external 5V power supply attached to Vin and Gnd. What is the minimum amperage required to do this? Can I assume that the max 0.5 A from the USB 2.0 spec is enough, or do I need more? I have been looking for MKR1000-specific documentation on this, but haven't found any.
It should be more than enough as it is based on a low power ARM.
Arduino writes
"The USB port can be used to supply power (5V) to the board.
The Arduino/Genuino MKR1000 is able to run with or without the Li-Po battery connected and has limited power consumption."
Gabriel_swe:
Arduino writes
Thanks, Gabriel_swe. I was hoping to get some more detailed specs than this so I know how much headroom I have to play with, but I guess this will have to do.
Ballscrewbob:
There is a page with battery life info too HERE
Excellent, thank you. According to that page, peak current draw for a wifi-enabled application is about 120 mA. Well under the USB 2.0 spec's 0.5A. (Would have been nice if they had put that information on the first page you linked.)
