Hello
I am using a 5v joystick with the Arduino MKR Wifi 1010, a 3.3v board. How do I power the joystick?
Note: I do not want to use level shifting as it will make my circuit more complicated.
How is that voltage used by the joystick? Does it contain any electronics?
Give us a link to this 5V joystick.
That joystick uses potentiometers. It is not a strictly 5V device though it is marked as such. Just connect your 3.3V to the 5V pin, ground to ground, Vrx and Vry to analog inputs.
0.1uF caps from Vrx and Vry to ground will help to filter noise and make the readings more steady.
Thank you.
I will try that.
