Powering Nano and SIM 800L
Hello,
I am building an SMS sender and receiver with an Arduino nano and a GPRS module named SIM 800L. The idea of the project is to power both with a battery so that I can work for a few months.
The SIM 800L board needs 5V and peaks of 2A. My idea was to use a 3.7 LiPo battery and a DC DC converter to power everything (arduino and SIM 800L) with 5V. However, I have tested the DC DC converter and it draws 0.4 mA by itself (with no load), which is too much provided that I want it to work for long time
Is there any elegant alternative to power Arduino nano and SIM 800L with a battery having minimum consumption?
Thanks.
What about using 2 x LiPo batteries in series then a regulator to get to your 5v ?
If your SIM 800L draws 2A then a residual of 0.4mA on the converter is maybe acceptable and you just need to size the battery to the load and the uptime you are trying to achieve.
Hope this helps.
The SIM800L itself is built to work directly from a 1S lithium cell (3-4,2V), since the chips/components inside are cellphone-parts.
// Per.
what voltage are you giving to arduino nano ? and how is it performing ?
I used this for a trial and am planning on using it with an a6 thinker sms chip. I think the a6 might be more efficient, I found that somewhere. I was able to power an Arduino for 6 weeks 10 sec/min on 3 aa batteries. I am planning on in the real project to use a lipo battery and only fire up once per day. I am hoping for greater than a year. I will use a 3.3v mini pro and remove the led and the regulator. With this setup, no need for sleep. The pro mini is more efficient that the uno or nano.
Anthony
