I have an a4988 stepper motor driver and a Nema17hs19 stepper motor.
Data sheet for the stepper motor: https://www.oyostepper.com/images/upload/File/17HS19-2004S1.pdf
The motor is rated to run at 3 V, however when looking at different sources this apparently is just a minimum value. From what i understand, is that as long as i provide the motor with its rated current, by correctly setting the RCS, i can power it with more voltage, this is because the A4988 takes a minimum of 8V so i would have to be powering it with 8 volts or more. Would this be ok?
Additionally the motor is rated for 2A, but in order to protect the a4988 which has a max current of 2a, i am going to run the motor at 1.5A. Would this still work?
This is a problem i've been struggling with for a while, i am very inexperienced in relation to stepper motors so any information would be much appreciated!
