I've got a project that uses a 12v solenoid and a nano, I've figured out the direct project wiring itself, (Using a TIP120 basically as a relay) but was wondering if I can use the battery to power the arduino and the solenoid.
I'll be using an 11.1v lipo (Or maybe a 7.4v)
I've heard using the onboard step down isn't very efficient and uses a lot of heat so was thinking would the battery into a buck converter into the Arduino work?
I'm thinking I'll wire it to the buck converter then solder off them points to the circuit/solenoid.
Will I need some sort of battery protection for the lipo? If so please can you suggest?
Alternatively I could power the arduino seperately with an 18650 1/2 of them, but I'm trying to keep this project as compact as possible
