Hi folks,
I've just obtained an Arduino Nano Matter board, have successfully ran the Hello World examples, and have gotten my first application to work — very exciting!
But now I've hit a problem. So far, I've been running on USB-C only, i.e., the Arduino Nano Matter board has been powered via USB-C and I've used the 3V3 pin to power my other electronic components. Now I want to use a stable 3.3V source that I have to power both the board and my electronic components. I read in the manual (https://docs.arduino.cc/tutorials/nano-matter/user-manual/#powering-the-board) that one can use the 3V3 PIN (not as power output but) as power input. So I tried to remove USB-C and power the chip via the 3V3 pin and the GND pin (I used the GND pin next to VIN and not the one next to D2). I have not changed any of the soldering jumpers (SJ2, SJ4, etc.) on the back side of the chip. Unfortunately, with this setup, nothing happens. I verified that 3V3-to-GND has the 3.3V coming from my source but that's it.
Can anybody advise on whether my setup is incorrect?
In the user manual, I have found the below figure butI am not 100% sure how to read it: do I have to cut SJ2?
Ideally, I'd want a setup where I can easily switch between using USB-C and my 3.3V power source.
Thank you for any pointers, comments, or ideas!
Best,
Hbf
P.S. I'm not sure this is related or points to a problem with my chip so just mentioning in case it rings a bell to anyone: when connected to USB-C, the voltage from GND to the +5V pin (next to A7) is almost zero, not the 5V I'd expect.
