Powermeter/dB Sensor
Hey guys, I want to start a project and i’m clueless in arduino even after reading a lot.
I have an rf route with some rf components/equipments connected, analog signals going through (wired). My goal is to check the dB of the rf wave in a certain frequency and bandwidth and show it on a gui eventually in my computer.
I can check it in a spectrum analyzer but my goal is to show it on my computer.
I was thinking about connecting arduino microcontroller/power sensor in each point I want to check, in order to do this I need RF IN input and RF OUT output to continue the chain without breaking it. I also need to consider the attenuation comes with the microcontroller/sensor I connect.
I need an advice how do I start with it?
-What components do I need, microcontroller/power sensor? And which one exactly is fitting my criteria?
-Where can I learn to code these specific components and rf waves?
Thanks in advance!!!
After some more research, I found out I can convert the analog signal to digital with raspberrypi and then measure the voltage going in the computer with an rs232 cable. Then how can I convert it back to analog?
Is it necessary or there is an other way?
My best guess would be to use a sound card, but really RPi questions belong to an RPi forum, not an Arduino forum.
Arduinos are not suited for sound processing.
I'm not sure. If I can use arduino then that's a done deal, it is analog signal eventually so I think there is something in arduino that can fit, not sure what tho..
A cheap SDR will do a very good job of an el-cheapo spectrum analyzer, and the SDR# software (free) does a very good jobe of displaying the spectrum on a PC. You can even use the combo to listen to the radio.
RF power meter boards, 100khz to 2.5Ghz are around £12, amybe use the Arduino to convert the output voltage into dBm.
I have a RF power meter with display (£30) which measures up to 6Ghz and its accurate, I checked it on a many £1000s spectrum analyser.
start here:
https://www.ebay.com/itm/0-1-2-4GHz-RF-power-module-measuring-RF-power-detector-measuring-high-frequenc/111755299277
https://www.ebay.com/itm/AD8307-RF-Power-Meter-Logarithmic-Testing-Detector-75-15-dbm-Module/373149646857
https://www.ebay.com/itm/AD8313-Module-Multi-stage-Demodulation-Logarithmic-Amplifier-RF-Log-Detector/272936816104
https://www.ebay.com/itm/1-8GHz-AD8318-RF-Power-Meter-Logarithmic-Detector-70dB-Dynamic-ALC-AGC-Control/383441885242
I would find an RF shop with calibrated equipment, and compare my results with theirs.
Thank you so much guys!!
So if I got it right I need an rf powermeter like the ones you linked me, and an arduino board/SDR/rpi to program on it? Then I can make sure it gets the frequency I want and outputs the dbm to the gui?
