Good afternoon everyone! ![]()
First of all...i really apologize for my bad english ![]()
I found in my garage this LCD: Powertip PG 240128-A of Powertip industries, I have seen from the datasheet that the controller is a Toshiba T6963C ...
the problem is that I can not in any way to control it with Arduino Duemilanove.
I do not know which library is to be used and if there is to adapt it to my LCD monitor ...
I am attaching also the Datasheet: http://www.powertipusa.com/pdf/pg240128a.pdf
I need help ...
Thank you very much. XD XD
It's a graphical LCD so you should start with a GLCD library.
Don
as the interface?
I have the same LCD screen with controller.
It is possible to connect it to an UNO but it'll take up almost every pin.
Here are the library files I used.
http://quasar.gotdns.org/arduino/T6963C_Library.zip
Example on how to use:
#include "T6963.h"
T6963 LCD(240,128,6,32);
Within the setup { }
LCD.Initialize();
Within the loop { }
LCD.writeStringLine(0, "Writing to line 1 of the LCD screen");
delay(2000);
LCD.writeStringLine(1, "Writing to line 2 of the LCD screen");
delay(2000);
LCD.clearText();
delay(2000);
Currently I'm @ work so I can't show you how to connect the pins to the arduino but you could figure it out from the code.
Thanks...but I did not understand how you can connect it to an arduino / duemilanove...can you share an image with links and sample code you use to make it work??
Thanks. ![]()
The sample code is as I posted in my previous message.
The datasheet can be found here.
As for the pin assignments, here's the table to link to the datasheet.
Datasheet / Arduino
1 / Ground
2 / +5v
4 / Analog port 3
5 / Analog port 1
6 / Analog port 0
7 / Digital port 2
8 / Digital port 3
9 / Digital port 4
10 / Digital port 5
11 / Digital port 6
12 / Digital port 7
13 / Digital port 8
14 / Digital port 9
15 / Analog port 2
The backlight is connected with a 10k (if I remember correctly) pot meter.
Pin 19 is connected with some sort of resistance between it.
I can't trace back the other pins since it came soldered with a ribbon cable making a traceback rather difficult.
tomorrow i'm going to make it work...i hope that the screen isn't broken...
do you have any photos of the screen connected to arduino???
Thanks. XD
Fardox
I just made these.
http://quasar.gotdns.org/arduino/IMG_0265.jpg
http://quasar.gotdns.org/arduino/IMG_0266.jpg
and http://quasar.gotdns.org/arduino/IMG_0267.jpg
Also, I forgot some pins in my previous post, I have added them now.
Old pic : http://quasar.gotdns.org/arduino/IMG_0052.jpg
Old movie running a demo : http://quasar.gotdns.org/arduino/IMG_0051.MOV
Thanks for the pics...tomorrow i want to make it work XD
Could you get those same pics online again?
I have PG 240128LRU-ATA-K and no idea how to connect it to my Arduino Uno.
Pics are online again. They where on the same server but the domain-name had to be altered.
Dear Ivo Oude Veldhuis
I am not able to access the images, its my request please send them again
U8GLIB_T6963_240X128 u8g(8, 9, 10, 11, 4, 5, 6, 7, 14, 15, 17, 18, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7, cs=14, a0=15, wr=17, rd=18, reset=16
to fardox
Hi redasat.
You need to speak up a bit.
Fardox is over 5 lightyears away, i don't think he'll hear you.
