Presence or Absence of a File on SD Card
if (digitalRead(22)==LOW)
      tmrpcm.play("/1/001.wav");
With above code and SD Card module as a simplest wave player
containing a folder named 1 and a file 001 I am having a very small issue and want to sort it.
If by mistake I forget to copy paste the wave file named 001.wav
and press Pin 22, the Arduino system get hanged or simply starts creating a noise on speakers
Like it is saying that "You dint upload the file and commanding me I am angry with you"
and I have to reset the system immediately
or
if it finds the file in the right place as per command , the player plays the file smoothly
So here,
no need to explain rest of the codes as it is available all the way everywhere on net
All I want is a code should be added like :-
If the WAVE is present
play the file
Else
do nothing or display empty file on serial monitor
Please guide me in designing that tiny script
Thanks a lot !!!! :blush:
K sir le me go thru that :blush:
Sir actually not able to understand that where and how this SD.exists will be applied
Still getting same issue
Not getting a correct script
Have a look at the SD library Files example
Yeah Looking there only but not a proper sequence i got
Can you please get me the URL where actually you are pointing ??
This one only
Is this one
It is an example available from the IDE
Oh ok ok le me go thru
Its partially working but not the exact rule with the code I am working right now
with that thing I deigned this one
if (SD.exists("001"))
    Serial.println("example.txt exists.");
    tmrpcm.play("001.wav");
    Serial.println("example.txt doesn't exist.");
    tmrpcm.play("");
But this one totally blocks the existing function of Arduino in beginning
Please correct it Sir
if (SD.exists("001"))   //test if a file named 001 exists
    Serial.println("example.txt exists.");  //print a message about a different file that you did not test for
    tmrpcm.play("001.wav");  //then play a completely different file, which may not exist
Your code makes no sense
Note my comments added to your code snippet
Please post your complete sketch
OK actually its a garbage of more than 15000 lines
I ll make a simple clean script then post it
Ya Sir Please have a look here as it is now a very important part
#include <stdio.h>
#include <Keypad.h>
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
TMRpcm tmrpcm;
#define SD_ChipSelectPin 53
const byte IN22 = 22;
const byte IN23 = 23;
const byte IN24 = 24;
const byte IN25 = 25;
boolean readValue22 ;
boolean readValue23 ;
boolean readValue24 ;
boolean readValue25 ;
  Serial.println("Begin..");
  tmrpcm.speakerPin = (46);
  if (!SD.begin(SD_ChipSelectPin))
    Serial.println("SD fail");
    return;
  pinMode (IN22, INPUT_PULLUP);
  pinMode (IN23, INPUT_PULLUP);
  pinMode (IN24, INPUT_PULLUP);
  pinMode (IN25, INPUT_PULLUP);
  if (digitalRead(22) == LOW)
      tmrpcm.play("/6/001.wav");
      tmrpcm.setVolume(5);
      tmrpcm.loop(1);
      delay(10);
      while( digitalRead(22) == LOW);
    if (digitalRead(37) == LOW)
      tmrpcm.play("/5/001.wav");
      tmrpcm.loop(1);
      delay(10);
      while( digitalRead(37) == LOW);
In this above section :-
I made 2 folders on SD Card named 5 and 6 in which folder 6 has some files but folder 5 has nothing and its completely empty
Now when I press Pin 22 the defined file runs
But doing same action with Pin 37
System gets hanged or distorted and rude sound starts almost
Just tested !!!
Why doesn't your code use the exists() function before trying to play the files ?
When I use to apply that one
The Player plays nothing and do nothing
just like
ALIVE BUT IN COMA !!!
Sir I tried all the way and failed too the same way there
So Kindly help me in solving the issue Please !!!!
Post a sketch with your attempt to use the exists() function
      if(SD.exists("001"))
      SD.exists("/6/001");
      tmrpcm.loop(1);
      delay(10);
This is just like
A Blind man throwing arrows and spear in a dark forest to kill the man eaters
No idea nothing just playing games with code !!!
      if(SD.exists("001"))  //check for a file named 001
      tmrpcm.play("/6/001.wav");  //play a completely different file
      SD.exists("/6/001");  //ignore whether or not the file you just played exists or not
Things are not getting any better, are they ?
See my comments
  • check whether the file you want to play exists
  • if so the play that file
