Hi all I'm very new to coding and would appreciate any help anyone can give me. I'm building a BMX gate from an open source:
bmx-start-gate/arduino/gate_seq at master · gndean/bmx-start-gate · GitHub
I've built two PCB's and I just can not get either to play the audio. Everything else works perfectly. I've got a feeling it is something to do with the sketch but I'm not sure. I would really appreciate any advice possible the sketch I'm using is:
//#define USE_LEDS 1
#define USE_NEOSTRIP 1
- This source depends on the following libraries. Install these before building the source.
- SD: To read from the SD card. https://www.arduino.cc/en/reference/SD
- TMRpcm: To output audio from WAV files on the SD card. GitHub - TMRh20/TMRpcm: Arduino library for asynchronous playback of PCM/WAV files direct from SD card. Arduino Uno,Nano,Mega etc supported
- TM1637: To drive the 7-segment display. Note: the exact library you need will depend on the model of display used
#include <SD.h>
#include <TMRpcm.h>
#include <TM1637.h>
const int PIN_UTRIG = 4;
const int PIN_UECHO = 2;
const int PIN_SPK = 9;
const int PIN_NEOPIX = 6;
const int PIN_SD_CS = 10;
const int PIN_SD_MISO = 12;
const int PIN_SD_MOSI = 11;
const int PIN_SD_SCK = 13;
const int PIN_SEGMENT_CLK = 7;
const int PIN_SEGMENT_DIO = 8;
const int PIN_START_BUTTON = A1;
const int PIN_CANCEL_BUTTON = A0;
const int PIN_MAG_RELAY = A2;
#ifdef USE_LEDS
const int PIN_R = 8;
const int PIN_Y1 = 7;
const int PIN_Y2 = 6;
const int PIN_G = 5;
#endif // USE_LEDS
const int NEOPIXEL_BRIGHTNESS = 200; // Setting to >= 200 lead to unreliability - the stick would stop responding
const int BEAM_BREAK_MIN_DURATION = 20; // Milliseconds
const unsigned long TIMING_TIMEOUT = 10000; // Milliseconds
const unsigned long GATE_ARMED_TIMEOUT = 2L * 60 * 1000; // Milliseconds
enum {
STATE_IDLE,
STATE_GATE_ARMED,
STATE_START_SEQ,
STATE_TIMING,
STATE_BEAM_BROKEN
enum {
LIGHT_ALLOFF,
LIGHT_WAIT_START,
LIGHT_R,
LIGHT_Y1,
LIGHT_Y2,
LIGHT_G,
LIGHT_FINISH
#ifdef USE_NEOSTRIP
Adafruit_NeoPixel neo_strip = Adafruit_NeoPixel(8, PIN_NEOPIX, NEO_GRB + NEO_KHZ800);
#endif // USE_NEOSTRIP
TMRpcm tmrpcm; // This needs to be global, otherwise resetting the Arduino fails to play audio
TM1637 segment(PIN_SEGMENT_CLK,PIN_SEGMENT_DIO);
int state;
int thresh_dist = 400;
unsigned long broken_beam_ms;
unsigned long timing_start_ms;
#ifdef USE_LEDS
pinMode(PIN_R, OUTPUT);
pinMode(PIN_Y1, OUTPUT);
pinMode(PIN_Y2, OUTPUT);
pinMode(PIN_G, OUTPUT);
#endif // USE_LEDS
pinMode(PIN_SPK, OUTPUT);
pinMode(PIN_UTRIG, OUTPUT);
pinMode(PIN_UECHO, INPUT);
pinMode(PIN_START_BUTTON, INPUT);
pinMode(PIN_CANCEL_BUTTON, INPUT);
pinMode(PIN_MAG_RELAY, OUTPUT);
segment.set(7);//BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
segment.init();
segment.clearDisplay();
#ifdef USE_NEOSTRIP
neo_strip.begin();
neo_strip.show();
randomSeed(analogRead(A5) + analogRead(A4) + analogRead(A3) + analogRead(A2) + analogRead(A1) + analogRead(A0));
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(PIN_SD_CS)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
//sd_print_root
tmrpcm.speakerPin = PIN_SPK;
tmrpcm.setVolume(5);
tmrpcm.quality(1);
tmrpcm.loop(0);
state_enter_idle();
bool test_loop_mode = false;
if (STATE_IDLE == state) {
if (LOW == digitalRead(PIN_START_BUTTON) || test_loop_mode) {
// Debounced wait for release of start button
delay(50);
if (!test_loop_mode) {
while (LOW == digitalRead(PIN_START_BUTTON)) {
delay(10);
delay(10);
// Arm the gate and play signal
digitalWrite(PIN_MAG_RELAY, HIGH);
state = STATE_GATE_ARMED;
tmrpcm.play((char*)"GATERISE.WAV");
// Wait till finished talking
while (tmrpcm.isPlaying()) {
delay(10);
// Remember this time to allow timeout
timing_start_ms = millis();
else if (STATE_GATE_ARMED == state) {
// Wait for start button
Serial.println("Start button pressed");
state = STATE_START_SEQ;
// Check for timeout of gate armed or reset button
if (((millis() - timing_start_ms) > GATE_ARMED_TIMEOUT) || check_for_reset_button()) {
tmrpcm.play((char*)"ABORT.WAV");
state_enter_idle();
else if (STATE_START_SEQ == state) {
show_start_light(LIGHT_ALLOFF);
Serial.println("OK riders. Random start.");
tmrpcm.play((char*)"RANDOM.WAV");
// Calibrate by measuring average distance for n seconds
unsigned long total_dist = 0;
int cnt_dist = 0;
while ((millis() - timing_start_ms) < 4000) {
total_dist += measure_distance();
cnt_dist++;
delay(10);
random();
if (check_for_reset_button()) {
// Abort. State will be reset
return;
int avg_dist = total_dist / cnt_dist;
thresh_dist = avg_dist * 2 / 3;
Serial.print("Calibrated distance: ");
Serial.println(avg_dist);
Serial.print("Threshold distance: ");
Serial.println(thresh_dist);
Serial.println("Riders ready. Watch the gate.");
tmrpcm.play((char*)"READY.WAV");
delay(10);
return;
int delay_ms = random(100, 2700);
Serial.print("Random delay = ");
Serial.println(delay_ms);
while ((millis() - timing_start_ms) < delay_ms) {
delay(10);
return;
show_start_light(LIGHT_R);
tmrpcm.play((char*)"T_LIGHT.WAV");
delay(120);
show_start_light(LIGHT_Y1);
delay(120);
show_start_light(LIGHT_Y2);
delay(120);
Serial.println("Green and gate drop");
tmrpcm.quality(0); // Drop quality now to minimise interference with usonic sensor timing
show_start_light(LIGHT_G);
digitalWrite(PIN_MAG_RELAY, LOW);
tmrpcm.play((char*)"T_GATE.WAV");
// Wait till finised playing audio before timing to ensure consistent usonic signal
delay(10);
// Format as seconds and show on display
String seconds = String((millis() - timing_start_ms) / 1000.0, 2);
display_seconds(seconds.c_str());
Serial.println("Timer active");
state = STATE_TIMING;
else if (STATE_TIMING == state) {
// Check if we've timed out
if ((millis() - timing_start_ms) > TIMING_TIMEOUT) {
Serial.println("Timing timeout");
tmrpcm.play((char*)"TIMEOUT.WAV");
state_enter_idle();
return;
// Allow reset button in this phase
return;
int dist = measure_distance();
//Serial.print("Distance: ");
//Serial.println(dist);
if (dist <= thresh_dist || test_loop_mode) {
broken_beam_ms = millis();
state = STATE_BEAM_BROKEN;
Serial.println("Beam broken");
delay(10);
else if (STATE_BEAM_BROKEN == state) {
if (dist > thresh_dist && (!test_loop_mode)) {
Serial.println("Beam lost");
else if (test_loop_mode || ((millis() - broken_beam_ms) >= BEAM_BREAK_MIN_DURATION)) {
// We're done
// Calculate time taken
unsigned long time_taken_ms = broken_beam_ms - timing_start_ms;
String seconds = String(time_taken_ms / 1000.0, 2);
Serial.print("Finished! Time taken = ");
Serial.println(seconds);
// Light up start lights
show_start_light(LIGHT_FINISH);
// We can switch back to full quality now
tmrpcm.quality(1);
tmrpcm.play((char*)"DING.WAV");
delay(10);
if (test_loop_mode) {
delay(5000);
// Clear start lights
// Output how long we took
speak_seconds(seconds);
// Back to the waiting state
state_enter_idle();
else {
// Beam is broken. Wait a little longer
delay(10);
else {
// Do nothing
delay(100);
void state_enter_idle() {
show_start_light(LIGHT_WAIT_START);
// Release the gate
state = STATE_IDLE;
void show_start_light(int light)
#ifdef USE_LEDS
if (LIGHT_FINISH == light) {
digitalWrite(PIN_R, HIGH);
digitalWrite(PIN_Y1, HIGH);
digitalWrite(PIN_Y2, HIGH);
digitalWrite(PIN_G, HIGH);
else if (LIGHT_WAIT_START == light) {
digitalWrite(PIN_R, LOW);
digitalWrite(PIN_Y2, LOW);
digitalWrite(PIN_G, LOW);
else {
digitalWrite(PIN_R, light == LIGHT_R ? HIGH : LOW);
digitalWrite(PIN_Y1, light == LIGHT_Y1 ? HIGH : LOW);
digitalWrite(PIN_Y2, light == LIGHT_Y2 ? HIGH : LOW);
digitalWrite(PIN_G, light == LIGHT_G ? HIGH : LOW);
#endif // USE_LEDS
#ifdef USE_NEOSTRIP
int b = NEOPIXEL_BRIGHTNESS;
for (int i = 0;i < 8;i++) {
neo_strip.setPixelColor(i, 0, b, 0);
neo_strip.setPixelColor(i, 0, 0, i == 7 ? b : 0);
else {
neo_strip.setPixelColor(7, light == LIGHT_R ? b : 0, 0, 0);
neo_strip.setPixelColor(6, light == LIGHT_R ? b : 0, 0, 0);
neo_strip.setPixelColor(5, light == LIGHT_Y1 ? b : 0, light == LIGHT_Y1 ? b : 0, 0);
neo_strip.setPixelColor(4, light == LIGHT_Y1 ? b : 0, light == LIGHT_Y1 ? b : 0, 0);
neo_strip.setPixelColor(3, light == LIGHT_Y2 ? b : 0, light == LIGHT_Y2 ? b : 0, 0);
neo_strip.setPixelColor(2, light == LIGHT_Y2 ? b : 0, light == LIGHT_Y2 ? b : 0, 0);
neo_strip.setPixelColor(1, 0, light == LIGHT_G ? b : 0, 0);
neo_strip.setPixelColor(0, 0, light == LIGHT_G ? b : 0, 0);
neo_strip.show();
void speak_seconds(String seconds)
for (int i = 0;i < seconds.length();i++) {
char c = seconds.c_str()[i];
if (c >= '0' && c <= '9') {
String fname = String(c);
fname.concat(".WAV");
tmrpcm.play((char*)fname.c_str());
else if (c == '.') {
tmrpcm.play((char*)"POINT.WAV");
delay(10);
tmrpcm.play((char*)"SECONDS.WAV");
// Returns state to waiting for start and returns true if reset button pressed
bool check_for_reset_button()
if (LOW == digitalRead(PIN_CANCEL_BUTTON)) {
Serial.println("Reset button pressed");
state_enter_idle();
return true;
return false;
void display_seconds(const char* seconds_c_str)
int8_t disp[4];
disp[0] = 17; // space
disp[1] = seconds_c_str[0] - '0';
disp[2] = seconds_c_str[2] - '0';
disp[3] = seconds_c_str[3] - '0';
segment.point(true);
segment.display(disp);
type or paste code here
