Presenting Bitlash, a command shell for Arduino
Hello:
Good day to all, and thanks for the many contributions which built this environment. What a pleasure it is to work with good tools.
Offered for your consideration is Bitlash, a command line shell for the Arduino serial port. I have found it useful here, and perhaps it will be useful for you, too.
Bitlash is an Arduino sketch; it runs on Arduino and interprets commands that you type in a terminal window:
print("hello, world", 2+2, 1<<3, a++==0)
hello, world 4 8 1
The standard Blink13 example is a one-liner in bitlash: the "while" command repeats the command while the test expression is true:
while 1: d13=!d13; delay(100)
^C
Bitlash is intended for those occasions when you need to bang some bits but writing a full Arduino sketch is overkill. But you can write simple apps in it. The command set includes most of the Arduino C functions. You can store compound commands in EEPROM as macros. Macros can call other macros. Infernal machines can be built.
Download, Doc, FAQ and Code Zoo can be found at: http://bitlash.net
I would welcome your feedback.
Cheers,
-br
Hello
Let me say thanks for the work that you have done. I like the concept as I think it would be useful for teaching beginners.
If I can propose a change is to have a version where the commands match the arduino statements. This would make this pefect for beginners to learn.
Good job
massimo
Hello, Massimo:
Thank you so much for your kind words, and your excellent suggestion.
I would appreciate your feedback on the improvements in compatibility in version 0.6
of Bitlash, which I have just made available.
I hope you will not mind if I paste the release notes here so that the thread stays intact.
My best regards,
-br
Bitlash 0.6 release highlights:
  • BACKGROUND MACROS and the run, stop, and ps commands, and snooze() for multi-tasking
    Bitlash can run up to 8 macros in the background
    while you work in the foreground at the command prompt.
  • COMPATIBILITY IMPROVEMENTS: Function names adjusted for better Arduino compatibility:
    Several names were changed to protect the innocent
    (beginners, at Massimo's suggestion - Thanks, Massimo!)
  • CUSTOM PROMPT MACRO: If there is a macro named 'prompt' it is run in place of
    printing the '>'. You can show the temperature, countdown, whatever you can measure.
Download link: http://bitlash.net/downloads/bitlash-0.6f.tgz
Bitlash home: http://bitlash.net
