Press and hold IR remote control button code
I am working on a robot car project and on lesson 2, i added an IR remote and i was wondering how i could make it so when you press and hold a button, the car will keep moving instead of moving for a little bit then stoping.
Here is the code i have now:
#include <ir_Lego_PF_BitStreamEncoder.h>
#include <boarddefs.h>
#include <IRremoteInt.h>
#include <IRremote.h>
/*  ___   ___  ___  _   _  ___   ___   ____ ___  ____
 * / _ \ /___)/ _ \| | | |/ _ \ / _ \ / ___) _ \|    \
 *| |_| |___ | |_| | |_| | |_| | |_| ( (__| |_| | | | |
 * \___/(___/ \___/ \__  |\___/ \___(_)____)___/|_|_|_|
 *                  (____/
 * www.osoyoo.com IR remote control smart car
 * program tutorial http://osoyoo.com/2018/12/14/osoyoo-smart-car-lesson-2-control-robot-car-through-infrared-remote/
 *  Copyright John Yu
#define IR_PIN    10 //IR receiver Signal pin connect to Arduino pin D10
 IRrecv IR(IR_PIN);  //   IRrecv object  IR get code from IR remoter
 decode_results IRresults;
#define speedPinR 9    //  RIGHT PWM pin connect MODEL-X ENA
#define RightDirectPin1  12    //Right Motor direction pin 1 to MODEL-X IN1
#define RightDirectPin2  11    //Right Motor direction pin 2 to MODEL-X IN2
#define speedPinL 6    // Left PWM pin connect MODEL-X ENB
#define LeftDirectPin1  7    //Left Motor direction pin 1 to MODEL-X IN3
#define LeftDirectPin2  8   //Left Motor direction pin 1 to MODEL-X IN4
 #define IR_ADVANCE       0x00FF18E7       //code from IR controller "▲" button
 #define IR_BACK          0x00FF4AB5       //code from IR controller "▼" button
 #define IR_RIGHT         0x00FF5AA5       //code from IR controller ">" button
 #define IR_LEFT          0x00FF10EF       //code from IR controller "<" button
 #define IR_STOP          0x00FF38C7       //code from IR controller "OK" button
 #define IR_turnsmallleft 0x00FFB04F       //code from IR controller "#" button
enum DN
  GO_ADVANCE, //go forward
  GO_LEFT, //left turn
  GO_RIGHT,//right turn
  GO_BACK,//backward
  STOP_STOP,
  DEF
}Drive_Num=DEF;
bool stopFlag = true;//set stop flag
bool JogFlag = false;
uint16_t JogTimeCnt = 0;
uint32_t JogTime=0;
uint8_t motor_update_flag = 0;
/***************motor control***************/
void go_Advance(void)  //Forward
  digitalWrite(RightDirectPin1, HIGH);
  digitalWrite(RightDirectPin2,LOW);
  digitalWrite(LeftDirectPin1,HIGH);
  digitalWrite(LeftDirectPin2,LOW);
  analogWrite(speedPinL,255);
  analogWrite(speedPinR,255);
void go_Left(int t=0)  //Turn left
  digitalWrite(LeftDirectPin1,LOW);
  digitalWrite(LeftDirectPin2,HIGH);
  analogWrite(speedPinL,200);
  analogWrite(speedPinR,200);
  delay(t);
void go_Right(int t=0)  //Turn right
  digitalWrite(RightDirectPin1, LOW);
  digitalWrite(RightDirectPin2,HIGH);
  delay(t);
void go_Back(int t=0)  //Reverse
  delay(t);
void stop_Stop()    //Stop
/**************detect IR code***************/
void do_IR_Tick()
  if(IR.decode(&IRresults))
    if(IRresults.value==IR_ADVANCE)
      Drive_Num=GO_ADVANCE;
    else if(IRresults.value==IR_RIGHT)
       Drive_Num=GO_RIGHT;
    else if(IRresults.value==IR_LEFT)
       Drive_Num=GO_LEFT;
    else if(IRresults.value==IR_BACK)
        Drive_Num=GO_BACK;
    else if(IRresults.value==IR_STOP)
        Drive_Num=STOP_STOP;
    IRresults.value = 0;
    IR.resume();
/**************car control**************/
void do_Drive_Tick()
    switch (Drive_Num)
      case GO_ADVANCE:go_Advance();JogFlag = true;JogTimeCnt = 1;JogTime=millis();break;//if GO_ADVANCE code is detected, then go advance
      case GO_LEFT: go_Left();JogFlag = true;JogTimeCnt = 1;JogTime=millis();break;//if GO_LEFT code is detected, then turn left
      case GO_RIGHT:  go_Right();JogFlag = true;JogTimeCnt = 1;JogTime=millis();break;//if GO_RIGHT code is detected, then turn right
      case GO_BACK: go_Back();JogFlag = true;JogTimeCnt = 1;JogTime=millis();break;//if GO_BACK code is detected, then backward
      case STOP_STOP: stop_Stop();JogTime = 0;break;//stop
      default:break;
    Drive_Num=DEF;
   //keep current moving mode for  200 millis seconds
    if(millis()-JogTime>=200)
      JogTime=millis();
      if(JogFlag == true)
        stopFlag = false;
        if(JogTimeCnt <= 0)
          JogFlag = false; stopFlag = true;
        JogTimeCnt--;
      if(stopFlag == true)
        JogTimeCnt=0;
        stop_Stop();
  pinMode(RightDirectPin1, OUTPUT);
  pinMode(RightDirectPin2, OUTPUT);
  pinMode(speedPinL, OUTPUT);
  pinMode(LeftDirectPin1, OUTPUT);
  pinMode(LeftDirectPin2, OUTPUT);
  pinMode(speedPinR, OUTPUT);
  stop_Stop();
  pinMode(IR_PIN, INPUT);
  digitalWrite(IR_PIN, HIGH);
  IR.enableIRIn();
  do_IR_Tick();
  do_Drive_Tick();
Try commenting this line - IRresults.value = 0;
When you comment it the car will not stop until you press the stop button
Not all IR remote buttons repeat. When they do they will typically send the same code again or a separate code that means 'repeat'. If you want some action to continue "as long as I am pressing the button" you need:
  1. A button on your remote that repeats.
    and
  2. A timer in your receiver to detect when the repeats have stopped.
    Each time a 'repeat' arrives, record the millis() time. When (millis() - recordedTime > TimeBetweenRepeats) you know that whatever was repeating has stopped.
@johnwasser I am using this IR remote with this IR receiver. Do you know if this repeats?
You can easily tell if a button on your remote repeats. Connect your receiver to an LED and see if it blinks once when you hold the button or blinks repeatedly as long as you hold the button.
