I'm completely new to Arduino's. I've done a few of the tutorials over on TinkerCAD and thought things were going well...
I have a very basic system whereby i'm using an L293D h-bridge with two push buttons and a motor. The idea is when I press and hold the first button, the motor will turn anti clockwise; release the button and the motor stops spinning. Press the other button and it turns anticlockwise etc...
I've attached a screenshot of the circuit (resistors = 10kOhm). Here is the code (i'm using 'raise' and 'lower' as this will eventually be used to control a vertically mounted linear actuator):
// define constants
const int RaiseButton = 13; //The button to raise the actuator is wired to pin 13
const int LowerButton = 11; //The button to lower the actuator is wired to pin 11
const int ClockwisePin = 4; //Input 1 into H-Bridge is wired to pin 4
const int AntiClockPin = 2; //Input 2 into H-Bridge is wired to pin 2
const int enablePin = 7;
// setup
pinMode(RaiseButton, INPUT); //Sets the raise button as an input
pinMode(LowerButton, INPUT); //Sets the lower button as an input
pinMode(ClockwisePin, OUTPUT); //Sets the input to the H-Bridge as an output
pinMode(AntiClockPin, OUTPUT); //Sets the input to the H-Bridge as an output
pinMode(enablePin, OUTPUT);
// loop
if (RaiseButton == HIGH) { //If the raise button is pressed,
digitalWrite(enablePin, HIGH); //then turn the motor on
digitalWrite(ClockwisePin, HIGH); //clockwise
digitalWrite(AntiClockPin, LOW);
else if (LowerButton == HIGH) { //if the lower button is pressed
digitalWrite(ClockwisePin, LOW); //anticlockwise
digitalWrite(AntiClockPin, HIGH);
//end of loop
As it stands, running the simulation and pressing either of the buttons does not turn the motor. Cannot figure out where i'm going wrong.
Paul_KD7HB:
The main part left out of you program is failure to actually READ the pin in to the constant you are checking.
Paul
Ok, i amended the code but still no luck. I think I interpreted your advice correctly?
// loop
digitalRead(RaiseButton);
digitalRead(LowerButton);
if (RaiseButton == HIGH) {//If the raise button is pressed,
//end of loop
DangerToMyself:
May help to know what motor your using.
Also, edit your post and swap out the quote tags with code tags.
Sorry, at the moment it's just in simulated form. I've attached a print screen of the circuit to my original post. The code will eventually be used to control a linear actuator.
Looking at your Fritz, looks like buttons are switching high side but you have pull UP resistors, so the input pins will always read HIGH whether the buttons are pressed or not.
val = digitalRead(inPin); // read the input pin
digitalWrite(ledPin, val); // sets the LED to the button's value
Paul
Ok, i've amended the code as shown below however the motor spins regardless of which button is being pressed. Also, the motor behaviour seems to depend on whether i define button states at the start as a global variable or within the loop as local (i.e. spins approx 16000rpm if defined as global, but approx 8000rpm if local), which I didn't expect.
// define constants
const int ClockwisePin = 4; //The input 3 into H-Bridge is wired to pin 4
const int AntiClockPin = 2; //The input 4 into H-Bridge is wired to pin 2
int RaiseButtonState = digitalRead(RaiseButton); //Read and store the state of the Raise Button
int LowerButtonState = digitalRead(LowerButton); //Read and store the state of the Lower Button
// setup
// loop
if (RaiseButtonState == HIGH){ //If the raise button is pressed,
if (LowerButtonState == HIGH){ //If the lower button is pressed,
digitalWrite(ClockwisePin, LOW); //anti clockwise
//end of loop
edgemoron:
My understanding of pull up resistors is that when button is not pressed, the input reads HIGH and when pressed the input reads LOW. Based on this i tried changing the if statement within the loop to check for LOW state rather than high, however the motor still continues to spin without either button pressed (see previous post for rest of code):
// loop
if (RaiseButtonState == LOW && LowerButtonState == HIGH){ //If the raise button is pressed and lower button isnt,
if (LowerButtonState == LOW && RaiseButtonState == HIGH){ //If the lower button is pressed and raise button isnt
//end of loop
Just realised i had my pull up resistors wired to the 9V line as opposed to ground. This is going to be a long journey isn't it haha. Seems to be working fine now, although motor doesn't stop when buttons are released. I'm sure i can figure that out though. Thanks for the input everyone, still used all tips to make it work.
Final code (feel free to critique further):
// define constants
// setup
// loop
//end of loop
