Rather than using an interrupt and software to increment a counter you might consider using one of the built-in timer-counters. I believe they can be driven by an external clock. Since the counting is done in hardware there is no software overhead. You would just read the register(s) to get the count. You can use the 16-bit timer/counter 1 to count up to 65535 or use the 8-bit timer/counter 2 to count up to 256. In either case you can have an interrupt signaled when the counter overflows so you can extend the count almost forever in software.
"Do it in software only if you can't do it in hardware." -Abraham Lincoln
