So, I'm working on a project at the moment - and the PCB I'm building for it is only two sided, as I intend to produce the PCB myself.
I'm using all surface mount parts, with all the signal and control lines etc on one side of the PCB - and am intending on putting all of the power circuitry on the other side of the PCB, i.e. regulator, polyfuses, tranzorbs, h-bridge, MOSFETs etc.
I'm worried about interference between devices that are driving noisy / inductive loads such as the H - Bridge as clearly there is no power plane in the middle of my PCB. I have ~ 5 MOSFETs and ~ 5 IGBTs driving inductive loads too with spikes clamped around ~400V.
Am I likely to experience problems with this? I'm reading app notes etc from multiple sources, most of which suggest of course filling as much of the board, both sides, as possible with ground copper.
What other precautions should I put in place? Or, should I 'breakout' the devices driving the inductive loads onto another PCB that is stacked on top with a full ground plane?
Many thanks in advance.
