Previously used AT328 cannot get Arduino Mega 2560 as ISP
Hello! So I was using my Arduino Mega 2560 as an ISP and successfully flashing my code onto my AT328PU chip and then I dropped my breadboards :frowning: and my Arduino stopped working as an ISP. I re-assembled my project and probably foolishly, I re-uploaded the Arduino as ISP sketch where SCK is 52, MISO 50, and MOSI 51 and this worked. However when I went to flash to AT328 it no longer worked. I tried re-burning the bootloader but haven’t been able to do this.
Here is my setup right now (same as previously):
AT328 pin 1 → Mega2560 RESET
AT328 pin 7, 8 — .1uF cap across — pin 7 to +5V, pin 8 to GND
AT328 pin 20, 22 — .1uF cap across — pin 20 +5V, pin 22 to GND
AT328 pin 9, 10 — 16MHz crystal across — pin 9 to 22pF to GND, pin 10 to 22pF to GND
AT328 pin 17 — Mega2560 pin 51
AT328 pin 18 — Mega2560 pin 50
AT328 pin 19 — Mega2560 pin 52
Mega2560 pin 10 to 10uF cap to GND
Mega2560 pin 9 to resistor to LED (track ISP is running via heartbeat)
All +5V and GNDs are rails common to Mega2560 GND and +5V outputs
This is exact set up I had before. I see the LED heartbeat flashing indicating that MEga2560 is running ISP script.
Then I try to flash a script I get this output (note that the first part of the output is just from my personal bat script that I use for flashing. It was working previously so not the culprit of the problem):
Cleaning preivous build...
rm -f piezo-0.elf piezo-0.hex
Building Project...
avr-gcc -mmcu=atmega328p -DF_CPU=16000000UL -Os -o piezo-0.elf piezo-0.c
avr-objcopy -O ihex -R .eeprom piezo-0.elf piezo-0.hex
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\jcbls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17\etc\avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : stk500v1
     Overriding Baud Rate          : 19200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : STK500
     Description     : Atmel STK500 Version 1.x firmware
     Hardware Version: 2
     Firmware Version: 1.18
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.09s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x020000
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Done!
Press any key to continue . . .
Here is the output when I try to upload a new bootloader (Tools→board–>Uno, Programmer → Arduino as ISP):
"C:\Users\jcbls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\jcbls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\jcbls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     PAGEL                         : PD7
     BS2                           : PC2
     RETRY pulse                   : SCK
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
     Hardware Version: 2
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
Reading | ################################################## | 100% 0.02s
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x000000avrdude: Yikes!  Invalid device signature.Double check connections and try again, or use -F to overridethis check.
Failed chip erase: uploading error: exit status 1
What should I be doing to re-establish the connection betwen mega2560 and at328? Again the at328 has been in use it is not fresh!!! so I imagine the steps are a bit different?
Thank you for your help in advance!
Is usually a sign of a bad connection. A breadboard is not a reliable setup. First of all check all connections with a DMM. Atmega328p pin to Mega pin. You will probably find something that is not connected (or wrongly) Ehen you succeed create a soldered version of your uploader.
Your ISP board (i.e Mega) should controls the Reset pin of the target board - on AT328.
So the connection above must be inverted - you need connect a digital pin of Mega to Reset on AT328.
Yep! that was silly of me lol – thank you for catching that
