Primary expression error before token 'or'
hey,
im working on a project with an rfid module to open and close a servo lock.
I was trying to add a button to open and close the lock and i keep getting this error:
here is the full code:
#include <SPI.h>
#include <RFID.h>
#include <Servo.h>
RFID rfid(10, 9);
unsigned char status;
unsigned char str[MAX_LEN];
const char BUTTON_PIN = 2;
String accessGranted [2] = {"8310119280"};
int accessGrantedSize = 1;
Servo lockServo;
int lockPos = 37;
int unlockPos = 115;
boolean locked = true;
int redLEDPin = 5;
int greenLEDPin = 6;
  SPI.begin();
  rfid.init();
  pinMode(redLEDPin, OUTPUT);
  pinMode(greenLEDPin, OUTPUT);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  digitalWrite(redLEDPin, HIGH);
  delay(200);
  digitalWrite(greenLEDPin, HIGH);
  delay(200);
  digitalWrite(redLEDPin, LOW);
  delay(200);
  digitalWrite(greenLEDPin, LOW);
  lockServo.attach(3);
  lockServo.write(lockPos);
  Serial.println("Place card/tag near reader...");
  if (rfid.findCard(PICC_REQIDL, str) == MI_OK)
    Serial.println("Card found");
    String temp = "";
    if (rfid.anticoll(str) == MI_OK)
      Serial.print("The card's ID number is : ");
      for (int i = 0; i < 4; i++)
        temp = temp + (0x0F & (str[i] >> 4));
        temp = temp + (0x0F & str[i]);
      Serial.println (temp);
      checkAccess (temp);
    rfid.selectTag(str);
  rfid.halt();
void checkAccess (String temp)
  boolean granted = false;
  for (int i=0; i <= (accessGrantedSize-1); i++)
  {bool currentState = digitalRead(BUTTON_PIN);
    if(accessGranted[i] == temp) or (currentState == false)
      Serial.println ("Access Granted");
      granted = true;
      if (locked == true)
          lockServo.write(unlockPos);
          locked = false;
      else if (locked == false)
          locked = true;
      delay(200);
      delay(200);
      delay(200);
      delay(200);
  if (granted == false)
    Serial.println ("Access Denied");
    delay(200);
    delay(200);
    delay(200);
    delay(200);
I really don't know what to do actually....
Welcome
Add parenthesis around the if
if ( (accessGranted[i] == temp) or (currentState == false) )
Prefer using || instead of or, and you don't necessarily need parenthesis around each conditions
if ( accessGranted[i] == temp || currentState == false )
