Primitive variable frequency PWM/synth
Primitive variable frequency PWM/synth proof of concept,
sort of a dds synthesizer.
Hello all. I wanted to prove that you could use floating
point math in an interrupt service routine. It works, but
sounds raw. It might be useful for people who want faster
frequency pulse width modulation. 10k sampling rate.
I am very busy the schoolwork, so I'm posting this in hopes
that someone can get some fun out of it.
Use at your own risk !!
#include <WProgram.h>
#include <FrequencyTimer2.h>
//Frequency pot:
//1k from +5V to ground, pot wiper to analog 0
//Pulse width pot:
//Speaker connection:
//pin 11 to 100ohm to speaker to ground
float n[10];
static long int y=0,x=0,on_=0;
static long int tmp=0;
static long l,f,c=0;
unsigned long  int time;
  pinMode(11,OUTPUT);
  f=0;
  Serial.begin(19200);
  delay(20);
  Serial.print("Ready");
  FrequencyTimer2::setOnOverflow( Burp);
  FrequencyTimer2::setPeriod(200);
  FrequencyTimer2::disable();
//extern "C"
void Burp(void) {
  n[0] = n[0] + 0.0055 * pow(2.0,(x>>4)/12.0);
  if (n[0]>=1.0) n[0] -= 1.0;
  if(n[0] >= y/1023.0) //pulse width 0.0 to 1.0
    if (l!=1)
     digitalWrite(11, HIGH);
     l=1 ;
    if (l!=0)
     digitalWrite(11, LOW);
     l=0 ;
  on_ = on_ +1;
  if (on_==10000) //1 sec mark
    Serial.print(millis()) ;
    on_ =0;
    f= 1;
  setup();
  time=millis() ;
  Serial.println(FrequencyTimer2::getPeriod());
  for(;;)
  //Serial.println(time);
   while( time + 1000 > millis()   )
     x = analogRead(0);
     y = analogRead(1);
     c++;
   f=0;
  //Serial.print((int)(10000.0*0.0055 * pow(2.0,(x>>4)/12.0))) ;
  //Serial.print("\t");
  //Serial.print(c);
  //Serial.println(x>>4) ;
   c =0;
  //time+=1000;
   time=millis();
I wanted to add that I attempted to use the "4us precision chronometer" for the above program but it just wouldn't work. It might be a more accurate function.
Also the board is a Duemilanove.
