Ciao a tutti, sono nuovo del mondo della programmazione e sto cercando di imparare e correggere i miei errori
seguendo un tutorial su youtube ho creata il mio manometro turbo e ora sono alle prese con il codice che anch'esso era presente ma in formato diverso da come serve al mio progetto, sicuramente voi saprete aiutarmi.
il codice è il seguente :
#include <GyverOLED.h>
GyverOLED<SSH1106_128x64> oled;
// This is the code required for the boot image. Use the GyverOLED BITmaper or ImageProcessor tool to create this code with your own image
const uint8_t mt_boost_128x64[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xC0, 0xE0, 0xE0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF8, 0xF8, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFC, 0xFC, 0xFC, 0xFC, 0x7C, 0x7C, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0xF8, 0xF8, 0xFC, 0x7C, 0x7C, 0xFC, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xE0, 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0xF8, 0xF8, 0xFC, 0x7C, 0x7C, 0xFC, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xE0, 0x00, 0x00, 0xC0, 0xF0, 0xF8, 0xF8, 0xFC, 0xFC, 0xFC, 0x7C, 0x7C, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xE0, 0x00, 0x70, 0x7C, 0x7C, 0x7C, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x0C, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0xFD, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xEF, 0x0F, 0x03, 0xE1, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x0F, 0x81, 0xF0, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x0F, 0xE1, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x0F, 0x81, 0xF0, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x8F, 0x81, 0x80, 0x80, 0x87, 0x9F, 0x9F, 0x3F, 0x7F, 0xFF, 0xFC, 0xF8, 0xFA, 0xF3, 0xE3, 0x83, 0x03, 0x03, 0x03, 0x00, 0x00, 0xC0, 0xF0, 0xFE, 0xFF, 0xFF, 0xFF, 0x3F, 0x0F, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x78, 0x78, 0x78, 0x78, 0x78, 0x78, 0x79, 0x7B, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x3F, 0x3F, 0x1F, 0x0F, 0x0F, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x78, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7D, 0x7C, 0x7E, 0x7F, 0x7F, 0x3F, 0x3F, 0x1F, 0x07, 0x01, 0x00, 0x3F, 0x3F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7C, 0x7C, 0x7E, 0x7F, 0x7F, 0x3F, 0x3F, 0x1F, 0x07, 0x01, 0x00, 0x3F, 0x3F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7C, 0x7C, 0x7E, 0x7F, 0x7F, 0x3F, 0x3F, 0x1F, 0x07, 0x01, 0x00, 0x0F, 0x1F, 0x3F, 0x3F, 0x7F, 0x7F, 0x7D, 0x7C, 0x7E, 0x7F, 0x7F, 0x3F, 0x3F, 0x1F, 0x0F, 0x01, 0x00, 0x00, 0x40, 0x78, 0x7E, 0x7F, 0x7F, 0x7F, 0x3F, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
float boostOutput = 0.0;
float peakBoost = 0.0;
float boostBarValue;
float peakBoostBar;
int boostBar;
oled.init();
oled.clear();
oled.drawBitmap(0, 0, mt_boost_128x64, 128, 64);
oled.update();
delay(1500);
// Lettura sensore
int sensorValue = analogRead(A0);
// Conversione PSI
if (sensorValue < 206) {
boostOutput = 0.0;
boostOutput = (sensorValue - 205) / 13.5;
// Peak boost
peakBoost = max(peakBoost, boostOutput);
// Conversione in BAR
boostBarValue = boostOutput * 0.0689476;
peakBoostBar = peakBoost * 0.0689476;
// Barra grafica
boostBar = constrain(boostOutput * 4, 0, 78);
// Display
oled.clear();
oled.setScale(4);
oled.setCursor(5, 1);
oled.print(boostBarValue, 2);
oled.print(" BAR");
oled.setScale(2);
oled.setCursor(5, 5);
oled.print("P:");
oled.print(peakBoostBar, 2);
// Barra boost (5 pixel di altezza)
for (int i = 0; i < 5; i++) {
oled.fastLineH(50 + i, 5, 5 + boostBar);
oled.update();
delay(100);
// Function for drawing lines. Pulled from GyverOLED library
void fastLineH ( int y, int x0, int x1, byte fill);
Ho provato a convertire i PSI in Bar e inserire i decimali
