Hello, I am reading register values with a Powermeter using MODBUS TCP with an ESP32 DEV Module. The output is as so:
As shown, the output are float values printed simultaneously without any separators, reason being that there is a data and error handler function:
void handleData(ModbusMessage response, uint32_t token)
float f;
response.get(3, f);
Serial.println(f);
void handleError(Error error, uint32_t token)
ModbusError me(error);
Serial.printf("Error response: %02X - %s\n", (int)me, (const char *)me);
I would like to print each value as a separate output, e.g. Voltage A =....., Current A = ...., etc in separate lines. How do I isolate and select data to be printed based on the response shown in the Serial monitor, how do I print isolated values based on this response?
I'm using the eModbus library. My code:
#include <Arduino.h>
#include <WiFi.h>
#include "REG_LIB.h"
#include "ModbusClientTCP.h"
#define baud 9600
#define TCPip 192, 168, 2, 46
WiFiClient theClient; // Set up a client
#ifndef MY_SSID
#define MY_SSID "Process_Trainer_Internal"
#endif
#ifndef MY_PASS
#define MY_PASS "92001329"
#endif
char ssid[] = MY_SSID; // SSID and ...
char pass[] = MY_PASS; // password for the WiFi network used
ModbusClientTCP MB(theClient);
float f;
response.get(3, f);
Serial.println(f);
Serial.begin(baud);
while (!Serial) {}
Serial.println("__ OK __");
WiFi.begin(ssid, pass);
delay(200);
Serial.print(". ");
IPAddress wIP = WiFi.localIP();
Serial.printf("WIFi IP address: %u.%u.%u.%u\n", wIP[0], wIP[1], wIP[2], wIP[3]);
MB.begin();
MB.onDataHandler(&handleData);
MB.onErrorHandler(&handleError);
MB.setTimeout(2000, 200);
MB.setTarget(IPAddress(TCPip), 502);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_CurrentA, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_CurrentB, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_CurrentC, 2);
//MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_CurrentN, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_VoltAB, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_VoltBC, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_VoltCA, 2);
// MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_AcPwrA, 2);
// MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_AcPwrB, 2);
// MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_AcPwrC, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_AcPwrTot, 2);
MB.addRequest((uint32_t)millis(), ID_meter, READ_HOLD_REGISTER, Reg_PwrFTot, 2);
delay(5000);
