Printing math gives inf
I use this code, en when printing get ovf.
Why is this?
typdouble xd=24.66e10,yd=32.54,zd;
float xf=12.4e+10,yf=98.67,zf;
  Serial.println(" test ");
  zd = xd * yd;
  Serial.println(zd);
  zf = xf * yf;
  Serial.println(zf);
}e or paste code here
From the reference documentation:
However,
xd is 2.466E100.
I suspect that double is 4 bytes on your system.
[edit]
Oops, that should be 2.466E11 as @anon94801460 said. Please disregard the explanation above.
Did you mean 2.466E11?
@PowerSoft You forgot to say which Arduino you are using, but on the Uno and others, Serial.print() does not support scientific notation, so it converts the integer part of the float/double to int32, which overflows at about 2.4e9.
Example.
while (!Serial);
float x = 2.1e9;
float y = 21.0e9;
Serial.println(x);
Serial.println(y);
Output
2100000000.00
ovf
